Old 24-03-2007, 09:47 AM   #1
Mark One
A humorous statement
Mark One's Avatar
Default What paint(s) are best used
Best used for painting the shroud in a cluster?
Black manual AU1 S.
S
Originally Posted by HLC
not using the search button makes the baby jesus cry.
Mark One is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2007, 10:12 AM   #2
mattp
mattp's Avatar
I'm about to do the same thing, just use a plastic primer, give it a sand, then use your colour. Once the primer's on you should be able to use any paint you like for your colour coat. Whether or not you use clear over the top is up to you, but it's probably not necessary. Cheers, Matt.
mattp is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2007, 11:04 AM   #3
Norton
Tuned by HPF
Norton's Avatar
I have found that the plastic dyes work the best, not a paint but a spray on dye. Should be available at the auto paint store.
Goes on better and will not scratch off like paint can, don't need to prime and sand also.
Norton
BF XR6T
Stock....For Now
www.aufalcon.com/norton :
Norton is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2007, 11:23 AM   #4
Mark One
Mark One's Avatar
Humm spray on plastic dye.
Black manual AU1 S.
S
Old 24-03-2007, 11:43 AM   #5
AU dude
Flying high...
AU dude's Avatar
I sprayed my centre dash using normal car paint. First I cleaned it with paint thinners, the sanded it, then paint thinners again, then used a primer, the 3 coats of car paint, then 2 coats of clear. All was sprayed using the compressor and air gun for a prefect finish. Then used toothpaste to buff and cut it back.
AU1 Forte - 17'' AU2 Tickford rims on all corners, Super low springs,
KYB shock absorbs + camber castor kit and a 3.45 LSD, Tickford snorkel,
3" mandrel intake, K&N pod in the box, Polished Rocker Cover.
AU dude is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2007, 05:06 PM   #6
Norton
Tuned by HPF
Norton's Avatar
Called "VHT Penetrating plastic dye"
Costs about $12 per can.
I did an entire car dash with different surfaces, plastic etc. worked very well with no primer, sanding, etc.
Good clean down with metho or prepsol, 2 to 3 coats ........All done!!
I kept the car for approx. 2 years and it still looked perfect.
BF XR6T
Stock....For Now
Old 24-03-2007, 05:14 PM   #7
mattp
mattp's Avatar
Hey Norton, does that work going from dark to light though? For example, if I want my black dash shroud to be silver?
Old 24-03-2007, 05:56 PM   #8
Mark One
Mark One's Avatar
I'm done, used plastic primer and the paint that goes with it. Also my cluster lights up red as well ;)
Black manual AU1 S.
S
Old 24-03-2007, 06:11 PM   #9
Norton
Tuned by HPF
Norton's Avatar
Don't know.......I used black over tan.
Best to ask a Auto paint store. Sorry I can't be of more assistance.
BF XR6T
Stock....For Now
Old 25-03-2007, 02:14 PM   #10
AU dude
Flying high...
AU dude's Avatar
....Also my cluster lights up red as well ;)
What bulbs did you use to make it do that?
Old 25-03-2007, 08:43 PM   #11
Mark One
Mark One's Avatar
I used tail light bulb dye on the cluster lights.
Black manual AU1 S.
S
Old 25-03-2007, 08:57 PM   #12
b2tf
not here much anymore
b2tf's Avatar
probably wouldnt come out the way it should, it'd be a darker version of the colour you were after. if youre going from dark to light colours,prime it and paint it.
2024 F150 XLT
Old 25-03-2007, 09:11 PM   #13
Norton
Tuned by HPF
Norton's Avatar
I agree.......I would only use the dye method going light to dark.
It does work well though, in the right application.
BF XR6T
Stock....For Now
Old 26-03-2007, 11:47 AM   #14
AU dude
Flying high...
AU dude's Avatar
I never knew there was such a thing, did you use this on the whole cluster face clear plastic?
Old 26-03-2007, 12:20 PM   #15
JefXR8
JefXR8's Avatar
Like a few peeps have said just scuff it back with some scotchbrite sorta like a scourer pad then put some plastic primer over it then paint it,looks the best by far!
JefXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2007, 04:02 PM   #16
mattp
mattp's Avatar
Yeah that's what I'll be doing. I'm going to go with a chrome / shadow chrome finish I reckon, see how it comes out. I've got a spare busted cluster lying around to practice on anyway. Cheers.
Old 26-03-2007, 08:29 PM   #17
Mark One
Mark One's Avatar
I dyed each bulb by itself.
Black manual AU1 S.
S
Thread Tools
Display Modes
