Old 01-04-2007, 05:18 PM   #1
toyotaxr8
toyotaxr8's Avatar
Default My New Manifold
A Few Pics of my new manifold on my 2002 AUII XR8, Tell me what you think
MR INCH
toyotaxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2007, 05:23 PM   #2
StealthAu
looks good what did it set you back?
StealthAu is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2007, 05:23 PM   #3
Bitmap
It's a beauty. Well done!
Bitmap is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2007, 05:23 PM   #4
JC
JC's Avatar
Looks great. Much difference in power, response etc?
Ford Performance Club ACT
Old 01-04-2007, 05:25 PM   #5
AU dude
Flying high...
AU dude's Avatar
Looks tuff, what increase in hp or kw did it give you over the standard manifold?
AU1 Forte - 17'' AU2 Tickford rims on all corners, Super low springs,
KYB shock absorbs + camber castor kit and a 3.45 LSD, Tickford snorkel,
3" mandrel intake, K&N pod in the box, Polished Rocker Cover.
AU dude is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2007, 05:25 PM   #6
302XLS
302XLS's Avatar
Have you noticed any gains with the new manifold? did you dyno before and after?
SEE MY CAR HERE
AND MAKE SURE TO VOTE!!!
302XLS is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2007, 05:26 PM   #7
toyotaxr8
toyotaxr8's Avatar
$1000 for the manifold+twin throttle bodies
$400 for new gaskets + all the seals on the injectors+ a 1/2 spacer
MR INCH
Old 01-04-2007, 05:29 PM   #8
toyotaxr8
toyotaxr8's Avatar
Its a lot more responsive and more top end
the car had 160.4 at the wheels before will get it tuned next week so i will post the new stats and the new and old dyno sheet then
MR INCH
Old 01-04-2007, 05:31 PM   #9
302XLS
302XLS's Avatar
here's a pic of mine
having it polished and have to tidy up the intakes. :
SEE MY CAR HERE
Old 01-04-2007, 05:40 PM   #10
toyotaxr8
toyotaxr8's Avatar
that looks cool what did you notice when you put yours on
and dose yours have runners and what length are they?
MR INCH
Old 01-04-2007, 05:44 PM   #11
302XLS
302XLS's Avatar
Ok, that's a bit too technical for me, as I had it put on for me. it did get a good mid to high end gain, but now have added a flash tune (generic) and once i get the 90 mm Maf from the states, pod filtler and sealed box built, cam and lifters installed will be going for a dyno tune to really get the best out of it.
SEE MY CAR HERE
Old 01-04-2007, 05:45 PM   #12
302XLS
302XLS's Avatar
was told today that i'll probably need to upgrade my injectors as well.
SEE MY CAR HERE
Old 01-04-2007, 05:54 PM   #13
toyotaxr8
toyotaxr8's Avatar
yes a bigger maf would do a lot i was going to get hold of a air box out of a BA the round style one with the cold air intake for a BA then heads and cam to get it really boogieing
MR INCH
Old 01-04-2007, 05:56 PM   #14
AUTickford
XD197
AUTickford's Avatar
both look awesome id love to have a crack at making one if i had a welder, what kind of throttle bodys are they? xf?
AUTickford is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2007, 05:59 PM   #15
toyotaxr8
toyotaxr8's Avatar
standard AUII 185kw V8 throttle bodies
MR INCH
Old 01-04-2007, 05:59 PM   #16
302XLS
302XLS's Avatar
what i've done for right now is to put the secondary intake in the front, had to cut a bit of the light housing away, but fit pretty well afterwards. made some increased airflow, but think with the pod with a G&D style box would do much better, I just reckon the $650 they ask for is a bit rich for a couple pieces of sheet metal and a pod filter and some tubing.
SEE MY CAR HERE
Old 01-04-2007, 06:01 PM   #17
302XLS
302XLS's Avatar
mine are the standard 64 mm tb as when i put the 90mm maf and 90mm tubing there's no point in going more than the twin 64.
SEE MY CAR HERE
Old 01-04-2007, 06:02 PM   #18
toyotaxr8
toyotaxr8's Avatar
have a go son make one your self
MR INCH
Old 02-04-2007, 07:51 PM   #19
toyotaxr8
toyotaxr8's Avatar
Were did you relocate the gang plug to?
MR INCH
Old 02-04-2007, 07:58 PM   #20
RG
Back to Le Frenchy
RG's Avatar
If you have the blue 24lb injectors you won't need to replace them. I still have them on mine and I have no issues.
Old 02-04-2007, 08:54 PM   #21
302XLS
302XLS's Avatar
Again, very technical for myself...... gang plug????? don't know what that is or where it goes, maybe a picture would help. There are a couple of plugs that the guy didn't connect, when i have it put back on when polished i'll have to make sure that all is connected though.
SEE MY CAR HERE
Old 02-04-2007, 08:55 PM   #22
302XLS
302XLS's Avatar
thanks red. those are the ones i have.
SEE MY CAR HERE
Old 02-04-2007, 09:01 PM   #23
toyotaxr8
toyotaxr8's Avatar
Look at the photo its highlighted in white
MR INCH
Old 02-04-2007, 10:11 PM   #24
philstoj
philstoj's Avatar
Hey there, noticed your avatar pic, what time did you run at the drags?
philstoj is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2007, 10:17 PM   #25
302XLS
302XLS's Avatar
ok, my throttle bodies are turned on there side, so that piece is on the bottom. I was told the throttle bodies were put like that as they would benifit with the way that they openned-better response apparently.
SEE MY CAR HERE
Old 02-04-2007, 10:17 PM   #26
toyotaxr8
toyotaxr8's Avatar
15.2828 at heathcote : was hoping for a high 14
I am going to heathcote again this month to run with the new manifold and see what it gets
MR INCH
Old 02-04-2007, 10:23 PM   #27
philstoj
philstoj's Avatar
What other mods do you have? is yours a manual or auto?
Stock the best time i could get was 14.90 lol, mine now is a bit of a struggle to get off the line cleanly, but has run a 14.7, now with edit it should do much better, only need better tyres lol.
Keep us posted on the results, manifold lloks good by the way.
Old 03-04-2007, 05:03 PM   #28
toyotaxr8
toyotaxr8's Avatar
shes the auto, i think the temp of the day killed it though it was 36 and hot as hell in the car
MR INCH
Thread Tools
Display Modes
