Old 24-05-2007, 10:00 PM   #1
[EDGHIA]
[EDGHIA]'s Avatar
Default Car audio.... wat do you think.
Hey guys i have recently purchased 3x 15" Soundstreem Picasso series subs.... they are 400RMS each and trying to think of the best way to amp them..... if i should run them off 1 mono block or 3??? wat would you do???
this is a seriouse thread aswell.... its not bull shiz
[EDGHIA] is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2007, 10:01 PM   #2
dave.747
dave.747's Avatar
Are they dual voice coil? 4 ohm, 2 ohm?
dave.747 is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2007, 10:02 PM   #3
ROOSTA
DFDFDF
ROOSTA's Avatar
How many voice coils and wat impedance (ohm) are they???
Cheers,
Nik
ROOSTA is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2007, 10:04 PM   #4
[EDGHIA]
[EDGHIA]'s Avatar
Power Handling: 400W/800W (RMS/Max)
Sensitivity: 85 dB
RMS Power Range : 400 Watts
Impedance: Dual 4 Ohm
Low Frequency response: 25 Hz
High Frequency Response: 500 Hz
FS - 28.7Hz
Qes - .849
Qms - 4.328
Qts - .710
Vas - 114ltrs
SPL - 87db
Mounting depth - 6.9"
Diameter: 15 Inch
Old 24-05-2007, 10:07 PM   #5
ROOSTA
DFDFDF
ROOSTA's Avatar
I would run one of the below combos..
2 x 15's wired to 1 ohm off 1 big mutha funkin d class..
2 x 15's wired to 2 ohm each off 2 d class mono blocks..
3 x 15's wired to 2 ohm each off 3 d class mono blocks..
Do you really need 3 x 15" subs in a falcon??? LOL..
Cheers,
Nik
Old 24-05-2007, 10:12 PM   #6
santoitaliano
BF F6, APV SR3900
santoitaliano's Avatar
3 is a ***** of a number of subs to run... I'd probably drop 1 or add another.. i dont think that you value boot space much.. with 4 then at least you can wire 2 in series and 2 in parallel and then get a nice 2 ohm final load on 1 massive mono..
what area you from? if i can help you with anything let me know..
Santo
White APV SR3900 [WIZZRD] (Click Here) [/COLOR]
Daily:
2006 Red BF F6 Typhoon
Bluepower enhanced.
santoitaliano is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2007, 10:25 PM   #7
[EDGHIA]
[EDGHIA]'s Avatar
thanks for the info guys.... i think i will run 3 mono blocks..... and yes i need 3 15" :P it need s to be big and unique..... plus dont worry they will fit :evil3:
Old 24-05-2007, 10:26 PM   #8
ROOSTA
DFDFDF
ROOSTA's Avatar
I know theyn will fit.. i did an install of 8 x 12" subs in a falcon and before that it was 4 x 15"..
3 will fit without even trying.. LOL..
Cheers,
Nik
Old 24-05-2007, 10:29 PM   #9
xrtonv
TICKFORD XR6
xrtonv's Avatar
Well seeing that ppl are offering to help with instaling sound system anybody interested in helping me make a 15 inch sub box?? lol
The Ride:Ford EF XR6 S1
The Drive Line: 4.0L MPI 4speed Auto TICKFORD ENHANCED
How she Rides: 15inch XR6 MAGS
Sound system:JVC head unit with AUX... 6 Inch in doors,rear with a Vnet 15inch & Infinity 12inch Subs In the Boot Running of a Coustic amp
The Mods: Pod Filter, exhaust......
Plans: Slam it on its ***, Sports exhaust( upgrade), Rims, Cam, CAI, Extractors +...
xrtonv is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2007, 10:30 PM   #10
[EDGHIA]
[EDGHIA]'s Avatar
Cheers,
Nik
yeah i would do 4 but i think it will break the dudbet on amps...... i dont really mind how much i spend but i dont wont it to drag out over a long time.... do you no if response do an amp that would suit thes subs good???
Old 24-05-2007, 10:33 PM   #11
ROOSTA
DFDFDF
ROOSTA's Avatar
I would personally go with 4 of the 15's and run them off 2 of the 1500wrms response d class mono's..
If you do decide to go with 3 subs.. 3 of the 800wrms response d class would do the job..
Retail price on the 1500wrms amps is $700 each.. and retail on the 800wrms is $400.. Cheaper if ya get a few at a time..
Cheers,
Nik
Old 24-05-2007, 10:39 PM   #12
-"Glowing" EF-
its getting worked on!
-"Glowing" EF-'s Avatar
or you can get 1200wrms clarion mono for $400
-"Glowing" EF- is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2007, 10:39 PM   #13
[EDGHIA]
[EDGHIA]'s Avatar
Cheers,
Nik
would only 800rms be that good??? i want them to be like crazy loud :P wat would it be like if i ran 3 on the 1500rms amp??
no clarion stuff is going in my car..... not a fan
Old 24-05-2007, 10:42 PM   #14
santoitaliano
BF F6, APV SR3900
run 4 off 2 800wrms monos
Santo
Daily:
Bluepower enhanced.
Old 24-05-2007, 10:44 PM   #15
[EDGHIA]
[EDGHIA]'s Avatar
lol nah its just a bit to HeKtIc for me...... you see 4 subs in car all the time.... but not 3 15"......
Old 24-05-2007, 10:44 PM   #16
-"Glowing" EF-
what you think of the latest MTX thunder amps, i heard they blow
Old 24-05-2007, 10:49 PM   #17
~EFhastE3~
~EFhastE3~'s Avatar
well in my opinion subwoofers are for chiks to go "oh my god... subwoofer!" im sure u'll make the right decision [EDGHIA] :
~EFhastE3~ is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2007, 10:50 PM   #18
ROOSTA
DFDFDF
ROOSTA's Avatar
How loud the system is is going to come down to enclosure design more than the equipment you use.. the old mentality of 25% equipment, 75% Installion comes to mind..
The problem with running 3 dual voice coil subs off one amp is that you will be presenting the amp with ~.6 or .7 ohms.. I have done this in the past and doesn't really give more noise but just decreases the amps efficiency and makes it heat up..
If you are looking at getting some response amps PM me when ya ready and i can hook you up with some good pricing..
Cheers,
Nik
Old 24-05-2007, 10:53 PM   #19
[EDGHIA]
[EDGHIA]'s Avatar
Cheers,
Nik
thanks mate, i wanna do it all soundstreem but its so expensive :S ill let you no if i need a good deal, thanks for the help.
Old 24-05-2007, 10:58 PM   #20
santoitaliano
BF F6, APV SR3900
stupid question.. why soundstream?
Santo
Daily:
Bluepower enhanced.
Old 24-05-2007, 10:59 PM   #21
[EDGHIA]
[EDGHIA]'s Avatar
i like the stuff the make and have seen some pretty wicked stereos with soundstreem stuff..... and yeah :P pluss i want the big chrome spider grills for the boot install...
Old 24-05-2007, 11:03 PM   #22
ROOSTA
DFDFDF
ROOSTA's Avatar
I just did some research..
http://www.soundstream.com/subwoofers-picasso.htm
Nice looking sub but it is missing some important specs.. did the subs come with a spec sheet.. Does it have the xmax listed???
Cheers,
Nik
Old 24-05-2007, 11:06 PM   #23
ROOSTA
DFDFDF
ROOSTA's Avatar
I dont know wat the pricing is like but might be worth looking at there amps.. they have a couple of decently specced d class mono blocks..
http://www.soundstream.com/amplifiers-picasso.htm
Cheers,
Nik
Old 24-05-2007, 11:07 PM   #24
[EDGHIA]
[EDGHIA]'s Avatar
yeah they do but ther about $700 each :togo: ... so i wanna get something a bit cheaper
Old 24-05-2007, 11:09 PM   #25
ROOSTA
DFDFDF
ROOSTA's Avatar
The xmax is how much 'throw' the sub has.. that is how far it travels when pumping.. It is usually a critical factor in determining how well the sub will go and wat size enclosure to run it in..
Cheers,
Nik
Old 24-05-2007, 11:12 PM   #26
[EDGHIA]
[EDGHIA]'s Avatar
umm.... i dont no the answer to that but the guys who will be doing the install work with soundstream alot so it should be sweet.... :
Old 24-05-2007, 11:44 PM   #27
santoitaliano
BF F6, APV SR3900
whos doing all the work...
chrome spider grilles are cool.. lol
roosta.. check out my subs mate.. www.jlaudio.com.. im running 2 x w3v3's... 12"...
3.0 cu.ft net vol.. facing into cabin.. kicker 750.1 pumping 465wrms into each.. i could prolly get a bit more out of them shifting the phase around 180 (eg into the boot), but i like the clarity and lack of boot rattle at the moment...
Santo
Daily:
Bluepower enhanced.
Old 24-05-2007, 11:56 PM   #28
ROOSTA
DFDFDF
ROOSTA's Avatar
Nice..
They look like a fairly tidy sub.. Plus coupled with a decent enclosure would give great noise..
Cheers,
Nik
Old 25-05-2007, 07:47 AM   #29
LTDHO
The one and only
LTDHO's Avatar
Glenn, one quick question.
Why do you need to run 3 15" subs?
Tuned by CVE Performance
Old 25-05-2007, 10:20 AM   #30
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
You can either Go Fast or Go Louder.............
Go Louder is alot safer and you wont loose your licence over it..........
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Originally Posted by rednose View Post
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
