Old 25-05-2005, 06:22 PM   #1
FordFan86
meow
FordFan86's Avatar
Default Limp Home mode? :S
This morning, on the way to tafe, started the car went to pic the 2nd chic up to give her a lift (ended up driving off after revving it to 4k outside her house) the trans was fine on the way there and then to the main road, i accelerated to ~70k and i hear this hollow winding noise/ hard to describe, anyway i backed off and went up again, same noise, so i took it easy for a little. Noticed the revs were sitting a little high, got pulled up at a set of lights. I took off and i noticed it was very sluggish, WOT and it very slowly climbs to 3k rpm. I think oh **** whats wrong, im locked in 3rd. Change down to 1st, up to 2nd and into drive, revs stayed where they were, no gear change at all. So im thinking shit. Anyway, turn the cruise button off (normally hit on when i get in the car) thinking no point using that when i get to the 80 zone, a few seconds later i change thru the gears again, and it seems i now have drive back. On the way home from tafe... all 4 gears, pefect, if not better than ever. I'm trying to work out how and why this happened? :\
(it's the damn chic with the ****ed trans in VR calais 5 litre cauzing this i swear )
EDIT: about 2 weeks ago i said to myself may as well get my trans serviced sometime, just clicked 200,000k and then i'll know it's done... weird how this just happened today lol
FordFan86 is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2005, 07:40 PM   #2
fairmont1998
fairmont1998's Avatar
It may be the inhibitor switch, move the shifter into 1st and accelerate from a standstill gently, if the trans changes out of 1st the inhibitor switch is faulty.
Current Rides:
2012 KK Jeep Cherokee Limited CRD - Still going strong
2019 MG ZS Essence
1988 RD Mitsubishi Colt GL - 59kW of Fury
2022 Kia Stinger GT
fairmont1998 is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2005, 08:08 PM   #3
FordFan86
meow
FordFan86's Avatar
Ok, thanks i will try that probably on friday when drive the car next.
Old 25-05-2005, 09:00 PM   #4
EB6
apprentice grease monkey
EB6's Avatar
so have a changed ya trans fluid yet or not, that can ahve a huge thing on how ya car goes.
EB6 is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2005, 08:16 AM   #5
FordFan86
meow
FordFan86's Avatar
Ok, dad took it out for a spin with me... gear changes perfect, redlined in 1st no probs didn't change he thinks i just had enough throttle to hold it in 3rd while i was changing thru the gears, but no cauz i braked for roundabouts etc. It was weird, i'm just going to get it booked in for a service. What's that involve and how much? Fluid, filter, clean magnets... do they adjust the bands on the BTR? :S
Old 26-05-2005, 01:53 PM   #6
ilsautomotive
Former E-Series Member
I understand there is more than 1 type of service, so when you get a quote be sure to ask what it includes.
ilsautomotive is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2005, 02:20 PM   #7
EDXR8
EDXR8's Avatar
Yep, new fluid, filter and adjust bands. Some places do complete fluid replacements which cost a fair bit more and a good idea if the fluid is burnt or the service is overdue.
EDXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2005, 09:57 PM   #8
EB6
EB6's Avatar
make sure they do a complete flush of the fluid, about 60% of its in the torque converter and ya cant get that out by just droppin the pan on the trans. the ford tq stuff cost me at trade about $20 for 4L and ya need up to 12 to do it properly so be ready for an expensive fluid change.
Old 26-05-2005, 11:08 PM   #9
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
It's roughly $180 for a full flush/service which is recommended. Some places can do an ECU test and tell you what the problem was that caused the car to go into LHM.
Old 27-05-2005, 10:54 AM   #10
FordFan86
meow
FordFan86's Avatar
Ok, just got off the phone with an auto place, Includes filter change, 2 band adjustments etc, $103 for that, and a flush at ~$56 if it is needed (ie really filthy in the pan) booked in for monday after next
Thread Tools
Display Modes
