Old 14-02-2008, 05:22 PM   #1
travisty
WNTDAU
travisty's Avatar
Default HP to VCT
hi i was just wondering what is involved and what needs to be changed if i put a vct motor in my xr6 that has a hp engine in it
aufalcon.com/travz_auxr6
travisty is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2008, 06:23 PM   #2
HLC
Audi S3
generally an engine conversion lol
Old 14-02-2008, 06:25 PM   #3
travisty
WNTDAU
travisty's Avatar
at choice ford in meloburne 1 bloke their says its fairly easy and another bloke goes its a massive job. i just thought its a straight swap of engine and ecu
Old 14-02-2008, 06:34 PM   #4
MGM
MGM's Avatar
thats what i would have thought, its the same engine isnt it but just has VCT
MGM is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2008, 06:40 PM   #5
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Why would you want to Dude .. VCT's are hard to do Performance work on .. Besides that , Changing Computers , Engines .. Lots of Little Expensive things ..
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2008, 06:47 PM   #6
travisty
WNTDAU
travisty's Avatar
its bcoz i was being a f@#$ing idiot and put my piston through my block so now i need a new engine and im thinking for a lil bit more $ i can get a better engine that has an extra 10kw
Old 14-02-2008, 07:01 PM   #7
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Whats 10kW's when you can get a AU Motor for $350 Reco'd? Slap the Exhaust on .. Bingo 10kW's ??
AU2PWR
Old 14-02-2008, 07:06 PM   #8
Racecraft
they call me Tibbo
Racecraft's Avatar
find a stocko low kay Au engine and add any choice of cam (or for that matter a vernier wheel and dial in the stocko) and you'll pick upmore than 10kw.. That would be not only smarter for further mods but would also be the cheaper of the options.
Racecraft is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2008, 07:16 PM   #9
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Hell yes .. Go on Ebay and theres always BUY IT NOW $350-400 Buck Low K AUFalcon Motors .. Jolly Rogers sells them for $500 with 6 Months Warranty
AU2PWR
Old 14-02-2008, 07:32 PM   #10
Racecraft
they call me Tibbo
Racecraft's Avatar
you put a piston thru the block? Did you damage any valves.. you might even be able to re use your HP head
Old 14-02-2008, 07:53 PM   #11
waggaclint
waggaclint's Avatar
im not sure but i think the wiring harness is different on the normal motors there is no wiring to plug into the VCT......im not 100% but somebody on here should no for sure....
waggaclint is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2008, 07:56 PM   #12
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Theres Plenty of other Options rather than Chucking a VCT into it .. Id Go with Racecrafts advice .. New Bottom End and use the HP Head
AU2PWR
Old 14-02-2008, 08:19 PM   #13
FGII-XR6
FGII-XR6's Avatar
is all the negativity finished now??????????????????????? Did he ask should he do it ? no did he ask your opinion? no he asked what he needed to do the job
if you get the VCT engine complete with the engine harness just drop it in and change the ECU the only other thing is you may need to run the VCT wire from the ECU to the main engine plug if its not there ( but i think it is ) your ECU will need to be trained to the BEM before the car will start
Old 14-02-2008, 08:26 PM   #14
rob_liss_lms10
rob_liss_lms10's Avatar
I agree he did want to know how to do it, but to buy a vct engine then adapt into the car seems over kill,there is only 8 flywheel kw's diff between the hp and vct, so about 5-6 rwkw, cetainly not worth the expense of an engine swap. Even if you did, vct's are a pain in the butt to mod, cams etc. I would buy a junker from the wreckers, then get a reconditioned short motor from repco...they need a swap.Usally the repco ones are bored to 1st size over, so as an added bonus you get a 4.1 ltr motor...and there is your extra kw's you want.
Red bull gives you wings?: nahhh.... we got our wings from TICKFORD
rob_liss_lms10 is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2008, 09:38 PM   #15
Peuty
Afterburner + skids =
Peuty's Avatar
But there is nothing wrong with guiding people in more logical directions is there?
Oo\===/oO
Old 14-02-2008, 09:42 PM   #16
b2tf
not here much anymore
b2tf's Avatar
I dont think it was negativity, but rather practicality. To be honest I personally wouldnt bother putting a VCT engine in unless I was going to leave it as a stock VCT engine, if I was going to mod I would leave the existing setup, get another HP engine or even a normal one, build it up and put it in, straight fit no worries.
2024 F150 XLT
Old 14-02-2008, 09:54 PM   #17
Racecraft
they call me Tibbo
Racecraft's Avatar
fair call... on the other hand lets just not bother trying to help each other out with cost effective solutions to problems... if you read the whole thread his reasoning behind the conversion was to pick up a measly 10kw... perhaps he didn't know about dialing in the HP cam, perhaps he didn't know that billet grinds are an off the shelf propostion for the HP and not the VCT, and maybe even he didnt know he might still be able to keep his XR head... But then again maybe we should of just let him spend the coin and be disappointed later
Old 15-02-2008, 01:32 PM   #18
travisty
WNTDAU
travisty's Avatar
thanks to evry one for helping out its good to see what other options i have. but would rather stick to a tickford engine because it is an xr
Old 15-02-2008, 01:43 PM   #19
FGII-XR6
FGII-XR6's Avatar
billet cams will be available for VCT engines in a couple of months according to crow. took a while but they finally got them right. recomendations are fine but not one person actually answered the initial question they just kept saying don't do it. as he has now stated this is the way he wants to go so we need to support him in this
Old 15-02-2008, 01:57 PM   #20
Racecraft
they call me Tibbo
Racecraft's Avatar
as I said earlier depending on the damage you can/could re use your head.. That is the only thing that makes it an XR.. THe bottom end is standard across the board.
Old 15-02-2008, 02:07 PM   #21
ClassicAU
Dude, for the amount of stuffing around its going to take to get it in there, why not just drop a Windsor in it!! It's still a Tickford motor. Although would be hells more expencive though. Just my 2c
Evan
ClassicAU is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2008, 09:07 PM   #22
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Motor is Unbolted , and New one is Bolted into the Existing engine Mounts .. New Wiring Harness is installed and i think thats about it ..
ive said what i think though .. and evan makes a very VERY good point ..
Daniel
AU2PWR
Thread Tools
Display Modes
