Old 09-10-2006, 06:28 PM   #1
AirStrike
AirStrike's Avatar
Default Rear speaker size for a KH Hatch
Just wondring if anyone know what the largest speaker is that will fit in the rear speaker grills in a KH hatch?
Dave
AirStrike is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2006, 07:05 PM   #2
AirStrike
AirStrike's Avatar
Any one?
Dave
Old 12-10-2006, 02:43 PM   #3
VippiN
What a performer!
VippiN's Avatar
Perhaps looking in the thread that was directly under the one you created.. Makes all our lives easier.
http://www.fordforums.com.au/showthread.php?t=68717
1981 Ford Laser KA :: E5 :: 2002-2003
1989 Ford Laser KE TX3 :: BP :: 2003-2007 75fwkW
1990 Ford Laser KF TX3 :: BP :: 2010-2011
1991 Ford Laser KF TX3 :: BP-T :: 2011-2015 109fwkW
2007 Ford Falcon BF XR6 Turbo Ute :: Barra 245T :: 2014-2019 324rwkW
1998 Ford Falcon AU XR8 Ute :: Windsor V8 :: 2019-2020
2008 Ford Fiesta XR4 :: Duratec 150 :: 2021-*
1998 Ford Falcon AU XR6 :: HP Intech :: 2021-*
VippiN is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2006, 09:45 AM   #4
AirStrike
AirStrike's Avatar
Thread contains no answers, just guesses.
Dave
2009 FG G6ET
394rwkw
11.76 @ 117 MPH (350rwkw)
Tuned by Blue Power Racing Developments
Old 15-10-2006, 09:29 PM   #5
el_sparko
turbo kid
el_sparko's Avatar
The biggest I could fit in to my kf tx3 turbs was a 5" so im guessing yours would be the same seeing all lasers use same rear speaker holders.
May I suggest you put your speakers in your parcel shelf as the rubber rebound on speakers vibrates on the plastic grille that comes with your laser and makes a horrible buzzing noise... not to mention anything taller than a basic speaker (including 2 ways) will NOT fit as there is not enough room between speaker holder and factory grille.
After all you can just pop off the grille, get a measuring tape out and see for yourself.
Good luck.
el_sparko is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2006, 11:39 PM   #6
mr_shagadalic
Thumbs up speaker size
i just fitted a pair of 6" 3way speakers to the back of my 1990 kf ghia,
they require new holes drilled but fit fine also plastic cover even leaves enough clearance
hope it helps
ps you need to remove the plastic panels first and their is 2 metric screws holding the metal bracket onto the body
mr_shagadalic is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2006, 07:13 PM   #7
AirStrike
AirStrike's Avatar
Thanks heaps for that everyone. Looks like I might go with them in the parcel shelf.
Dave
2009 FG G6ET
394rwkw
Old 29-10-2006, 12:53 PM   #8
xespack
I just fitted some 6.5 inch splits to the back of my KF. I took out the plastic grilles and made a piece of mdf the same shape and mounted them to that. Fits well with the ring that holds the metal speaker grille overhanging about 10mm on the inside. The mdf gives a nice solid surface too, theres no vibrations and they sound solid.
xespack is offline   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
