22-01-2007, 02:32 AM | #1 | |||
V8 wannaabeee
Well,I'm getting extreme slowness, this is after the 3rd HOP .. so any ideas? I've never heard of a 1.1.1.1 ip.. only 127.0.0.0 ?
I have 8000/384k connection, though the lag is on the 3rd hop (which intern is causing every other hop to be lagged) thus my connection is really slow I could barely bring up fordforums. Quote:
22-01-2007, 03:21 AM | #2 | ||
lpg = big boom!
1.1.1.1 is a lan ip,
i would wither put it down to you are on a rim with its own mux... (doubtful) or its just the speedtouch being screwey...
BF Futura Dedicated E-GAS w/Ghia bling Project: 86 ZL Fairlane, Red, Sunroof, 310,000KM |
22-01-2007, 03:40 AM | #3 | ||
V8 wannaabeee
well I am on TPG 8000/386k ADSL ... this is the network goes like:
Computers>Wireless/Wired-Switch>Speedtouch-Modem>Internet I just hope that it isn't data getting sent to, or out ... because if I am lagging in the 1000's .. than alot of data must be flowing through... thus it goes straight to my bloody download quota which is a measly 40GB. I'm not sure what platform I am on?? what's wrong with mux or a rim, I know they're not good as everyone talks about them, but what are they is it like a congested network or something? As far as TPG know I'm not suppose to be connected to this new plan (untill 7th of feb.) .. but I've had an awesome 800kbps downloads for nearly 2 weeks now?? |
22-01-2007, 07:18 AM | #4 | ||
Tried rebooting everything? Compuer, modem, router, switch, etc.
See if that helps.
Cheers, Sam. |
22-01-2007, 08:59 AM | #5 | ||
Ausfactor.com
It looks like your running 2 routers there. Hop 1 and 2 are both running NAT, is there any reason for this?
[Insert something witty here] |
22-01-2007, 10:43 AM | #6 | |||
Right out sideways
call Tpg , i did before xmas, as i was getting a lag spike every 2 minutes on the dot on XBOX live, and web browsing was nearly non-existant. She told me they had a different login doman or something to try, i changed my login address in router, and it was instantly fixed.
May or may not apply fix whats happening to you though. I thought i would try the same ping you did, although i am in nsw Quote:
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302 |
22-01-2007, 12:35 PM | #7 | ||
What time of the day is it happening? It may be peak periods
22-01-2007, 01:14 PM | #8 | ||
V8 wannaabeee
The lag has seemed to subsided so I dunno, I won't know if it's a one off thing or going to be regular, see if it happens tonight.
22-01-2007, 01:32 PM | #9 | |||
Built Ford Tough
Black on white '83 SWB F100 C6 auto 351C on gas and on the ground --> Project Thread '55 F100, just a roller at the moment, new project Silver MY12 Volkswagen Amarok |
22-01-2007, 02:12 PM | #10 | ||
I suspect someone has misread RFC 3069 when implementing their aggregator.
http://www.faqs.org/rfcs/rfc3069.html |
22-01-2007, 02:20 PM | #11 | ||
V8 wannaabeee
As I said I never heard of an ip address of 1.1.1.1, I haven't changed a thing on the network for a very long time ? too long to remember ;) . So I dunno why it all of a sudden wants to lag, if it happens again tonight i'll see what I can do...
22-01-2007, 04:11 PM | #12 | |||
No. 3 Should be the address for the ISP shouldn't it?
Now driving an unbreakable Hilux, which is becoming full of rust : |
22-01-2007, 04:13 PM | #13 | ||
we have 10.1.1.1 which is for the router/modem to reset it and test for connectivity etc
22-01-2007, 04:17 PM | #14 | |||
Where's all the IT professionals? I'm still learning about it.
22-01-2007, 04:31 PM | #15 | ||
I'd say its either an address on your router or an address your ISP has decided to use.
Either way, ringing your ISP to ask them to fix it is probably your best bet. If you haven't tried it, try rebooting your router. |
22-01-2007, 04:46 PM | #16 | ||
Oh FFS.
It is a DSL connection. The IP is an "illegal" public IP and will be on an interface of whatever aggregator the system uses whether it is a DSLAM or IPSN or Passporte or whatever. Usually this is a private IP that complies with RFC 1918 but is really irrelevent so long as the internal tables of the system recognise it. It is within their private bgp area and not broadcast so external routers do not care. It was probably used because whomever set up the system was not very sure what they were doing and followed the instruction manual to the letter. Basicly IT MEANS NOTHING. Why were your ICMP echos so long? Probably you had crap running running the background you were not aware of or the aggregator was overloaded or if you are on a minimux in a RIM then backhaul is congested or about 40 bazillion other reasons. |
22-01-2007, 06:06 PM | #17 | ||
N E R D S
:P Just kidding. MY connection slowed RIGHT down as well & i just disconnected EVERYTHING and plugged it all back in and it was fine, but your problem seems alot worse than mine. |
