Old 23-01-2007, 08:37 PM   #1
toadsmoker
Default Heater pipe advice
Hello everyone. New to these forums and new to AU's. Bought an AUII wagon a few months ago and been lovin it so far, big step up from the old EL.
Had a few problems with it, auto rebuilt and radiator replaced under warranty.
Thought I was on top of the cooling system but its still using water, seems to be leaking from the heater pipe at the rear of the water pump.
After searching the forum it seems to be common problem. Whats the easiest way of fixing this? Taking the water pump off or can I get at it from behind by taking the heater pipe out?
toadsmoker is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2007, 08:44 PM   #2
EvilChief
Boost Addict
taking that heater pipe off can be a tad tricky as there are a few bracket holding in place, one under the extractors. i normally use sealant to stop leaks, works at least for a while
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build)
Ford BA XR6T Ute - daily driver
Ford FG XR6T Sedan - cruiser
do you see a general trend? I DO
Can't live with it, can't live without it!
EvilChief is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2007, 09:27 PM   #3
toadsmoker
So go for taking the water pump off?
The consensus seems to be the o ring goes, I wouldn't be able to get sealant in there.
I'm abit surprised its just a push fitting, no clamps or anything.
Old 24-01-2007, 08:41 AM   #4
Mechan1k
Mechan1k's Avatar
It's a pretty tight push fitting though ... and the water pump is bolted in quite well.
Old 24-01-2007, 11:49 AM   #5
EvilChief
Boost Addict
id remove the water pipe and water pump, as i said before it will require removing extractors and it will be pretty tricky.
last time i had to use a set of strap down ratchets to brake the water pipe out as it was nicely rusted in
N12 Pulsar - sold
Old 24-01-2007, 12:18 PM   #6
atec77
Read your manual , pull the rad , serpintine alenator brackets loose and lay it down then pull the pump , you will need a soft hammer to help the pipe losse , add a new o ring and some silastic around it and assemble making sure you oull the pipe fully forward and install a new pump gskt after cleaning the mating surfaces , takes some time but it's worth it , check the heater change over under the inlet manifold for rust as well.
atec77 is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2007, 05:43 PM   #7
toadsmoker
Thanks everyone, dosn't sound like a real easy job so I might watch it for a few days till I'm absolutly sure thats where its coming from.
