24-02-2007, 10:19 PM | #1 | ||
I'm looking to put some money into a transmission. At first, I was going to get an auto and put some work into it, but then I decided I was going to get a manual. Both of those ideas fell through, and now I have a bit of money to put towards either of them.
I have a 90 MPFI EA, 4 speed at the moment, which I'm thinking may not last too much longer. What would I be better off getting? I know a manual will kill a stock auto, but if I put a bit of money into an auto, is there any chance of it keeping up with a manual? I realise that in the end, a manual would probably be cheaper, but an auto is generally cheaper to maintain in the long-run? I suppose it depends how often you go through your clutch, etc though. Basically, I just don't know what to get for my car. I don't have my manual license, but it's not much to get one. What am I going to get more performance out of? Help me decide!! :P |
24-02-2007, 10:23 PM | #2 | ||
Former E-Series Member
To compete with manual, an auto not only needs some sort of shift kit but much shorter diff gearing.
As for running costs, are you factoring in manual's better fuel efficiency? A properly driven manual clutch should last a long time. |
24-02-2007, 10:24 PM | #3 | ||
Parts bin special
A tuned auto might be slightly quicker for an inexperienced manual driver, but a manual is heaps more fun. With a bit of experience, you should be able to perfect your takeoffs so you'll be much quicker than the auto. I found the manual certainly feels faster than the auto, particularily out of the corners
Weekender 1964 US Falcon Futura convertible - Rangoon Red 260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels https://fordforums.com.au/showthread.php?t=11470868 Daily 2014 SZII Territory diesel - basic runabout Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more 2000 AUII Fairmont - XR wheels, Ghia interior 2010 FG XR50T ute - XR8 bonnet, Streetfighter intake |
24-02-2007, 10:42 PM | #4 | ||
A decent auto that will not only keep up but beat a manual will cost you heaps.
Clutches last for ages mate as long as they are installed properly. Ive had my PBR XR clutch in for 6 months now and it fell's just as good as it did the day I put it in And im not shy about thrashing it neither it regularly gets feed curry.;) But yer i can comment on a worked auto but a stock 5 speed with a stock clutch feels so much stronger then any 4 speed BTR ive ever driven. 1 vot for manual. |
24-02-2007, 11:05 PM | #5 | ||
Vote 2 for manual.....
24-02-2007, 11:23 PM | #6 | ||
If I were to get an auto that would have a chance of keeping up with a manual, I'd be looking at roughly $1500 at the bare minimum, yeh?
Whereas a manual will cost about $800 tops? Leaning towards a manual, but I don't want to end up buying a dud..It's not easy to "kill" a manual, right? Most of the time, it'll be the clutch that stuffs up? Also, at some stage in the future, I'd be looking to put an AU motor into the EA (That's possible with the MPFI setup, yeh?). If I were to get a T5 out of a E-Series, will it still bolt up without too much trouble? |
24-02-2007, 11:39 PM | #7 | ||
Parts bin special
My entire manual conversion totalled around $600 (including snags, beer, and softdrink for all the people that helped fit it). I have been very happy with mine. There is a slight risk that something could go wrong with the manual, but you could say the same about the auto. Plus if something did go wrong in the manual, it would be cheaper to rebuild than the auto
24-02-2007, 11:47 PM | #8 | |||
If you do go for a manual I would suggest getting an EB2 onwards box as they usally have lower k's and are a little bit more refind over the EA box. There's nothing wrong with EA box's tho just theres alot of claped out examples going around. A e-series T5 box will marrie up to the AU blonk no worries but you will have to drill some new holes in the bottom of the bellhousing as they dont line up on the block apart from that its a strait swap. |
25-02-2007, 01:00 AM | #9 | |||
need more boost
EDIT: i checked my dyno sheet today and my "claimed" 113rwkw was actually 103rwkw, which resulted in a 15.6 at calder. I have seen e-series with more power run far slower times. Go manual
'94 ED Falcon GLi Suspended by: kings, koni, pedders Rolls on: 17" AJR Director's Stops due to: bendix, DBA Shifter connected to: T5 manual Power from: ??? Interior: velour and woodgrain Cost: stuff all :P |
25-02-2007, 11:41 AM | #10 | ||
wild xr8
i'm having the same drama with my el, the main thing with strengthening the auto wat they call k bands. 2 bands, 1 from 1st to 3rd, the other 2nd to 4th. this reduces slip when fed lots of power. cost round 400. plus u probably would do a service on it to. they are a strong box the ford 4 speeds. if u go manual, the early 5 speeds xf - ed are stronger than ef onwards.
25-02-2007, 01:14 PM | #11 | |||
Still leaning towards the manual. With the money I have saved, I could afford a manual conversion plus some new wheels. Best of both worlds! :P
If I'm still looking to put the AU motor in, would I be better off putting an AU manual in as well? I'd assume they're basically the same, albeit a bit more priceier, but with lower km's. Quote:
25-02-2007, 03:00 PM | #12 | ||
MADED.6
go the manual i havent been in or seen a fast e-series auto yet even one with shift kit and 3000rpm stall and 3.9 diff gears he still cant break the 14 second barrier and how many ppl get 14's with manuals. seriously go manual if u are after some fun and a bit of a faster car. but if u drive in traffic alot the start to **** u trust me i have mine with an exedy clutch now and i hate driving in traffic.
cheers josh.
TUFAU-8 Get Stroked. AU Stroked 5.6L GHIA |
25-02-2007, 03:23 PM | #13 | ||
AU II XR8
Vote manual
AU XR8 II ute XD FAIRMONT GHIA 302 XA FAIRMONT 302 TOPLOADER |
25-02-2007, 03:38 PM | #14 | ||
ED XR6
HAS to be a manual.
Look at it this way, you'll feel tougher than your auto-driving mates. You'll come off a better driver. |
25-02-2007, 05:06 PM | #15 | ||
I would agree a manual can be more fun, but a good shift kit a stall converter and some decent power behind it is just as fun. I've got an auto in mine I was thinking about going manual for my new engine with supercharger but all the trans shops I went to told me it wouldn't last build up the auto!
Also i've kept up with plenty of 5 speeds with my auto! |
25-02-2007, 05:51 PM | #16 | ||
Shoot.
In an E-Series, better make it a manual ;) Unless it's a hardcore turbo
20V Turbo |
25-02-2007, 06:36 PM | #17 | ||
Manual, for sure, go 5 Speed... when you learn how to drive it, and you'll really move ;)
2015 FGX XR8 - 557rwkw on E85 KPM Street Fighter PCMTec Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19 Shockworks Coilovers PITLANE AUTOMOTIVE & PERFORMANCE
25-02-2007, 06:44 PM | #18 | ||
Traino!
yeah i would say manual, but i am finding out now they cost a lot of money (clutch), but its worth it
Previous Cars: EB 2 XR8 - 5 Speed, All Black, SSV Bodykit, EF 2 XR6 - 5 Speed, XR Kit, Sunroof, Current Car: EL GLI - Straight As! |
25-02-2007, 06:53 PM | #19 | ||
Smile
An auto with a good stall converter will put most manuals behind you.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
25-02-2007, 06:55 PM | #20 | ||
BTRs can handle decent power as long as they've got adequate cooling.
That is, when your BTR is in operational mode T5s are for mild cars at best |
25-02-2007, 07:32 PM | #21 | ||
EBII XR6
Manual all the way mate, I've never looked back since driving my car, being a manual, for over a year now.
DEVLXR
25-02-2007, 08:21 PM | #22 | ||
Weezland
Auto with the correct stall convertor will KILL a manual,an auto will lose less speed between gearchanges regardless of how good a driver you think you are.
An auto with correct stall will multiply torque off the line and be quicker over the first 60',what you gain at the 60 you can double,or even triple sometimes at the line over a 1/4 mile.. This is the only reason I didnt run into the 10 second bracket while running 125mph. T5 are also weak as ****s,flat shift em or abuse them too much and its just a matter of time.. |
25-02-2007, 08:38 PM | #23 | ||
To get some decent power out of an auto, I understand I'd need a stall converter, shorter diff gears, and a decent cam, at the least?
How does a stall-converter work? From what I can gather, it doesn't send power to the wheels until it's at a certain RPM, or something along those lines? Basically, what goes into a worked auto transmission that'll give some decent power (I don't exactly expect a 10 second car either..) What kind of price would you be looking at for a decent setup on an auto? Still just looking at all my options. : |
25-02-2007, 08:41 PM | #24 | ||
you've got it in one.
Stallies can be had for $400 upwards, and I'm assuming you have a six judging by your avatar. Get a 2.5k stally, 4.11 gears (prices vary, you can get pintara gears for as little as $150ish) and a cam ($couplahunje) with a power band that comes in around the 2.5k mark and you'll be laughing. |
25-02-2007, 08:50 PM | #25 | |||
Smile
25-02-2007, 08:54 PM | #26 | ||
^^^ I guess I should've elaborated a little.
As Stav says, it won't engage at a specific RPM point all the time every single time. My 3000rpm stally would engage below 2000rpm if I just took off at a crawling pace. But it would flash at 3000rpm if I took off full-throttle. |
26-02-2007, 06:30 AM | #27 | ||
V8 Ute V8 Boat
all i need to say is
MANUAL FTW
VE SS Ute manual 09 AU XR8 UTE 200KW manual 02 Challanger Ski boat V8 01 125 Thumpster 2010 Swag All set for the weekend |
26-02-2007, 01:51 PM | #28 | |||
wild xr8
26-02-2007, 02:43 PM | #29 | |||
Weezland
A high stall convertor will allow you to use what power you have efficiently during take off,but will also flash to at least that stall speed on gear changes at WOT,at part throttle slower take offs it will behave almost like a stock one. If you are going to fit a cam,and go auto,choose stall convertor last,so you get one that will stall a little higher than peak torque with the new cams power band,that way the stall speed takes advantage of everything the engine has at launch.. |
