Festoon This!!!
Hey guys, I was browsing on ebay and I came across this XG ute that said it had VS Commo injectors? Now he also said not to ask just that they make a big difference.
Has anyone heard of this? and if so is it worth doing? Cheers, Matt |
![]() Join Date: Dec 2004
I might be wrong but I think E-Series, 90s Magna and Commodore injectors are interchangable and have similar flow rates (19-24lb?)
I'm not sure about Commodore injectors but I think Magna ones offer an improvement over std E-Series 19lb units |
The one and only
I bought my injectors of v8capri who had them in his VN.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
Just Cruzing
i think im not sure but the magna blue top injectors are the one you want if ya want injectors.
Dark Blue 96 EL XR6 MOD'S Herrod Extractors & Redback exhaust lowered Au xr6 rims Successful Trades with:BradensEBxr6, snypereb, EDXR6T, ORSMF6 _______________________
Festoon This!!!
Oh well there ya go lol. Would it be worth changing the magna injectors or is the difference minimal? Would you need to change the ecu?
Matt |
i'm assuming that we qre talking about 6 cylinders?
VFII SS UTE
holden run a return to tank setup
whereas ford don't the holden fuel pump run at 60 p.s.i. in that thier is your answer
I don't often hear the sound of a screaming LSX. But when I do, So do the neighbours.. GO SOUTHS
#8 | |||
Festoon This!!!
#9 | |||
The one and only
#10 | |||
Festoon This!!!
Matt |
#11 | |||
VFII SS UTE
you may need a holley blue and a recale of you softwear to get the benefit's other wise pointless
#12 | ||
wouldnt putting in VN/Manga injectors over fuel a E series if running standard ECU?
2015 FGX XR8 - 557rwkw on E85 KPM Street Fighter PCMTec Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19 Shockworks Coilovers PITLANE AUTOMOTIVE & PERFORMANCE
#13 | |||
VFII SS UTE
as the vn/vr run 23 p.s.i. injectors (note i don't know the ford fuel pressure this may leed to over fuelling) as the holden run return exess fuel for the fuel with is not needed
#14 | ||
Falcons have a return line as well. And injectors aren't measured by pressure.
#15 | ||
23lb injector, the lb is for pound right? but not pounds per square inch?
#16 | |||
VFII SS UTE
but holden goes bye 125milliseconn@60psi =idol to a max .925 milli @60psi if this helps vn/vr injected fuel before the intake valve opened @ 12psi (poor atomisation) ecotec injected while valve open better fuel efienct @60psi
#17 | ||||
From what I remember the Magna/HSV injectors flow 23lb in Magnas and HSVs, but the fuel pressure in the Falcons is lower so they flow 21 or so. Quote:
#18 | ||
Any injector change to a different flowing injector will require a ECU change to get correct fueling, if you change the fuel pressure to get it correct, you will have no benefit at all, and actually may be worse off due to incorrect spray pattern due to the pressure change.
#19 | ||
I build your wish list...
fords run rich anyway .. and there has all ready been threads on this over the years .. not much point putting in bigger injectors with out needing it
If it weren’t for physics and the law enforcement, I’d be unstoppable.
#20 | ||
on an EA engine with an EL XR6 ECU, will EL XR6 injectors make a difference?
Damon
EBII XR6 5 spd
>>MY CAR!!<< Pacemakers, 2 1/2 Sports Exhaust, Thermos, XH Snorkel, KnN Panel Filter, Custom Black Interior, 18x8 Speedy Graphites with King Super Lows.. and more mods to come! JVC Touch Screen Head Unit, Front - Pioneer 220w 6" splits, Back - Pioneer 220w 6" (all amped), Pioneer 12" 1000w sub, Powered by Pioneer 800w Mono Amp 127.51rwkw |
#21 | |||
VFII SS UTE
and i noticed it didn't run a return (not that i seen) reapairing solid heater pipe.
#22 | ||
ORSM FORD CRUSIERS
the only real gain you are going to acheive by running bigger injectors is if you have a DIRTY BIG cam and advance the timming otherwise the stock injectors will be able to produce the amount of fuel needed. personaly i wouldn't bother unless you are going boosted.
BLUEPOWER RACING DEVELOPMENTS Strive for perfection in everything we do. Take the best that exists and make it better. When it does not exist, design it. Accept nothing nearly right or good enough. -[BLKPHN] (VIC) PLATES FOR SALE $495.00-
#23 | |||
Festoon This!!!
Matt |
#24 | |||
The ELXR6 ECU will be calibrated to the BBM intake and thermo's and smartlock, and the ELXR injectors are the same as a EA, im pretty sure when they went AU there was a slight difference, but still then they run at 19lb. The XR ECU will run the fuel pressure at 300kpa thats about it, and be calibrated to 3.45 Gear Ratio... If im wrong, please correct me cheers - Grechie
#25 | |||
Festoon This!!!
#26 | |||
nope, but if u have a auto, and you leave it in D, it might shift up earlier
