Old 13-09-2007, 09:02 PM   #1
Van D
Van D's Avatar
Default Caliper painting.
OK, so I made a thread in paint & panel, but as the first one disappeared when the forums crashed with no replies and it doesn't get that many views anyway, I thought i'd try here real quick as I want to get it started tomorrow as I go away on the weekend.
Basically, I want to paint my brake calipers, but the standard caliper paint isn't what i'm after colour wise (VHT don't even make a white). I'm looking to do a surf/mint green to match the colour my car will be, or to do a white at least.
I've spoken to a forum member who said they used a VHT caliper paint as undercoat then went over it with the paint used on the car, hoping that it will work. But the car isn't on the road yet, and from my understanding they're not 100% on it.
Has anyone else done it that way with success? Is there any other way of getting the colour i'm after, even if it's custom made?
The alternative I have in mind is using a VHT flame proof paint as they at least come in white and the only difference I could see is that it stands up to a higher temp rating.
Any help is appreciated, and if mods don't want this thread to run, just delete it with my apologies!
Originally Posted by irlewy86
Holden made the decision to make thier utes for pretty boys years ago. Wannabe tradesman drive them. If my son came home and told me he bought a holden ute I would struggle to come to grips with the fact he is a homosexual.
Van D is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2007, 09:12 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
I did this on my TC Cortina, even got the brakes so hot you could smell the brake pads when I stopped, never had an issue with the paint, I did paint them the same colour as the car which was a dark green. Painted for at least 2or3 years, front disc, rear drums.
All the spray paint I used came in cans off the shelf.
Owner of first ever car to retrofit BA SSS - the EA2BA
Send me a PM if you want to know anything
2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
EA2BA is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2007, 09:17 PM   #3
gthofan
Gunna girlie-man
gthofan's Avatar
What are the legal rules with spraying calipers? is it a legal/roadworthy issue?
WADE CAMS-- UNLEASH THE POWER!!
<INSERT WITTY SIGNATURE HERE>
Daily- 05' BA futura... work done.
Cruiser- 85' VK berlina... more work done
gthofan is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2007, 09:23 PM   #4
The G6ET Spot
That can't be a serious question.
The G6ET Spot is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2007, 09:30 PM   #5
Van D
Van D's Avatar
Beautiful! Cheers mate.
I want the green to look as bright and pop as much as possible (going silver base on the actual car), would I be best using the flameproof white as an undercoat/base, or something like the cast aluminium brake caliper paint?
Old 13-09-2007, 09:30 PM   #6
Van D
Van D's Avatar
Doubt it mate, they're painted from factory!
Old 13-09-2007, 09:33 PM   #7
gthofan
Gunna girlie-man
gthofan's Avatar
Oh well excuse me then. I wouldnt have put the friggin question up for fun! Asked a simple question (apparently) and given a ridiculous answer. thanks very much :
Old 13-09-2007, 09:41 PM   #8
chrispie123
didnt efghia get nabbed for having painted calipers ages ago,
chrispie123 is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2007, 09:44 PM   #9
gthofan
Gunna girlie-man
gthofan's Avatar
yes he did, but im not sure if they have changed the rules since then
Old 13-09-2007, 10:02 PM   #10
Allen
You win again, gravity!!!
Allen's Avatar
I did my fronts with the VHT stuff, simply because it looks better than surface rust! :P
Certainly looks heaps better than stock... I'm not worried about the colour match to the duco, as they get covered in dust anyway, so as long is its roughly the same colour it'll look good.
And these calipers didn't have any paint on them at all from factory... hence the rust:P
1966 Fairlane 500 XL
Allen is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2007, 10:06 PM   #11
Nevermind
Goodbye XR8
Nevermind's Avatar
I painted mine with just cheap off the shelf basic spray paint from bunnings.
I didnt have any troubles with peeling or anything, just touched it up every 6 - 12 months.
I basically just cleaned them, undercoat and a couple layres of what ever colour you wanted (I wanted red). the undercoat was only used to help bring out the brightness.
Mazda 3 MPS Sports in Hot Red.
Nevermind is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2007, 10:27 PM   #12
b2tf
not here much anymore
b2tf's Avatar
VHT Flameproof will be fine, the caliper paint is more just for those who come in and say "I want caliper paint" - there's bugger all difference between it and normal VHT stuff. From memory though the caliper paint does come in white, can check that for you on Sunday (Ive got the whole range in stock @ work).
You'd be right to use it as an undercoat then a normal paint for a topcoat, Id probably recommend a clear coat over that though (VHT do make one as well).
I wanna do my calipers Mandarin to be a bit different so Ive looked into it a bit.
2024 F150 XLT
Old 13-09-2007, 10:41 PM   #13
Van D
Van D's Avatar
Sweet.
I'll head down to ricerbahn or something tomorrow to check it out. There wasn't a white caliper paint on their site, but that wouldn't mean they don't make them. If I don't get it all sorted and purchased tomorrow, it'd definitely be great if you could have a look at work. Oh yeah, and I was gonna grab their clear as well to make it nice and easy.
Cheers mate.
Old 13-09-2007, 10:43 PM   #14
Van D
Van D's Avatar
Hmm, perhaps the factory coat on them was/is enough for the heat protection anyway?
Old 13-09-2007, 11:10 PM   #15
InfernoSR
Sales Representative
InfernoSR's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For research and posted write up on cooling system care and repair in AU.COM and offering help where possible
Ive got the whole range in stock @ work.
Whats the closest colour to Blueprint do you have in the VHT range that i can use for calipers?
InfernoSR is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2007, 02:24 AM   #16
Zed7fiddy
Temporary Australian
Zed7fiddy's Avatar
Awesome news, White flameproof Base and a couple of Harvest green coats and clear
Pics in two weeks :
Zed7fiddy is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2007, 02:59 AM   #17
JC
Miami Pilot
JC's Avatar
I've said it before, and I'll say it again - if your calipers ever get hot enough to warrant some sort of heatproof paint, then you have bigger things to worry about than the paint peeling.
You can use ANY paint you like on callipers. Export paint is the best cheap brand I have found - just make sure you clean the brakes properly with brake clean, then prepsol, then prime, then paint, then clear coat if you want. You can buy all 3 cans of paint required above for under $10, or 1 can of useless VHT caliper paint (only useless because it's like $15, and no better than the $2.99 stuff from bunnings)
Ford Performance Club ACT
Old 14-09-2007, 05:19 AM   #18
agony
BLOWN 383 CHEV OWNER
Scott what would be the issue with painting the caliper? How would that make it illegal/unroadworthy?
agony is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2007, 05:23 AM   #19
agony
Originally Posted by Van D
I've spoken to a forum member who said they used a VHT caliper paint as undercoat then went over it with the paint used on the car, hoping that it will work. But the car isn't on the road yet, and from my understanding they're not 100% on it.Cheers
Like others have said I don't see the caliper getting that hot it melts the paint, the disc would be a different story. I have painted my discs with the same method I did the calipers with. I also have a few mates that have had there discs powder coated, don't know how that stands up for heat?
Old 14-09-2007, 07:55 AM   #20
Charliewool
Bolt Nerd
Charliewool's Avatar
Not calipers, but looking at doing the hubs of my discs... They are badly oxidised from using various alloy wheel cleaners, and also go rusty in a flash.
Would High temp engine enamel be ok for these?
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4
Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD
Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD
2 wheels.. 2015 103ci HD Wideglide.. SOLD
SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida!
(Ex Blood Orange #023 FPV Pursuit owner : )
Charliewool is online now   Reply With Quote Multi-Quote with this Post
Old 14-09-2007, 08:57 AM   #21
agony
Not sure mate. I used brake paint as an undercoat then gave the hubs a couple of coats of engine enamel so I'm hoping that system works, time will tell.
Old 14-09-2007, 09:52 AM   #22
boss-290
boss-290's Avatar
http://www.fordforums.com.au/showthr...liper+painting
boss-290 is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2007, 09:53 AM   #23
b2tf
b2tf's Avatar
Sweet.
Cheers mate.
I'll have a look and get you a part number. Same goes for Blueprint, Ill see what we can do. Shameless plug though - any Autobarn store can mix blueprint for you into an aerosol can in about 10 mins. I can mix any Ford colour you like, all I need is a code.
2024 F150 XLT
Old 14-09-2007, 04:49 PM   #24
Van D
Van D's Avatar
Well I picked up a can of silver VHT caliper paint today, not wanting to risk it peeling (for the sake of 5 bucks anyway!). I'm going to use it as an undercoat after cleaning them up with a wire wheel/brake cleaner/prepsol then take them to my painter who will shoot them with a surf green and clear.
Now, one other question.. What exactly can I paint? I'm planning to pull them apart as i'll be doing the seals and what not anyway. Can I paint the guide pins or will I have clearance/rub issues? I was just going to do them a white with no gloss coats so it won't be thick or anything.
Old 14-09-2007, 11:43 PM   #25
InfernoSR
InfernoSR's Avatar
So all in all... can i use a brake hub black paint as the undercoat of the caliper, then spray it in Blueprint 2pac or enamel? YOu said Autobahn can mix up a batch for an aerosol can, but is that an enamel, 2pac or what?
Old 15-09-2007, 06:47 PM   #26
dave351cid
playing in my big shed
dave351cid's Avatar
i have used VHT engine paint (ford light blue ) on the calipers and disc hubs on the XB . it has lasted for years no worries.
the metal backing plate of the pads themselfs and right on the edges of the disc next to the wear surface on the rears discoloured a bit after some serious burnout comps . talking about major abuse here and normal street driving i doubt there would be any issues.
i will do the BA one day but havent decided what colour will match the acid rush. maybe i should see autobahn and get a can of acid rush and do the calipers and dust plate ????
`75 XB FAIRMONT sedan . mushroom beige, injected 351, toploader, 9inch
`10 FG XR50 Turbo ute. Nitro blue, 6 sp Auto, Leather trim.
`04 BA RTV tray back, Red, V8 auto,
`04 BA XR6 Turbo sedan. Blueprint. auto, Leather trim.
`03 BA XLS ute . Acid Rush, factory lpg, auto,
`48 TEA20 Grey Ferguson,
`62 Willys 6-230 , 4x4 light truck
`04 Yamaha TTR 250
dave351cid is offline   Reply With Quote Multi-Quote with this Post
