30-03-2008, 12:02 AM | #1 | ||
hey guys, just joined up like 3 days ago so still new here,
got a problem wit ma AU, wen it idles its really rough and sounds like the engine is chocking and sumtimes it just drops revs then revs up again. the car is straight gas, has never happened before and ive had the car for 2 years, any ideas wat it is, some1 said that i have to re-tune the idle, like unplug battery and reset comp and teach hw to idle properly. dunno thanks in advanced peace |
30-03-2008, 01:26 AM | #2 | ||
Boost Addict
go to aufalcon.com and read up on idle relearn procedures in the tech section.
roigh idle tends to point towards dirty or faulty ISC (idle bypass valve), located on top of the throttle body. being gas you have a few more items to play with, ie mixter, etc last wiuered issue we had at work with a straight gas falcon was, that the gas inlet hat located on top of the throttle body has cracked and was no longer secured properly and was allowing air to enter post this gas inlet ring.
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO Can't live with it, can't live without it! |
31-03-2008, 10:14 AM | #3 | ||
you may also have to get the converter serviced, it may have gummed up on the idle jet and is causing issues
31-03-2008, 10:19 AM | #4 | ||
I guess its gas, so :
Check you leads and sparks. Check that water is flowing freely ( A recent trouble of mine ) Clean/check your Idle speed controller. Also do you know what kind of gas system it is? |
31-03-2008, 10:37 AM | #5 | ||
ive checked leads and sparks, all good
water is flowing i had someone check the idle speed controller, said its all good well the gas system is factory gas, so dunno wat they use, yesterday i checked it out again and sounds like there isnt enough gas going into engine, i checked and cleaned air filter and everything. i think i have to get the mixture fixed. |
31-03-2008, 11:41 AM | #6 | ||
Get someone qualified to clean the idle jet out ... how old is the Vialle converter in it????
Have heard of the diaphram breaking down and the internals of the converter gumming up ... and even corroding out (if not using the correct coolant mixture ... or just using water to fill cooling system).
31-03-2008, 12:22 PM | #7 | ||
ok everyone the weirdest thing just happened, i took out the battery because i was fixing my sound sytem, i also just added abit more oil to engine.
plug battery back in and the engine is running like new, can someone explain this to me? i took it for a 20 min drive and tested it a different speeds and stuff and its running perfect. so weird, but im scared that i might have done something that even though its running smooth im in deed wrecking the engine. |
31-03-2008, 12:35 PM | #8 | ||
Sounds like it may just have needed an ECU reset
Matt. |
31-03-2008, 09:56 PM | #9 | ||
the only problem with that is, pretty soon it will probably be back to where it was in the beginning as you haven't actually replaced anything....
31-03-2008, 10:14 PM | #10 | ||
yer im just waiting for that day, because i know its gona happen, and itll happen wen im like far far away from home.
wednesday its gona get a check up, so hopefully they can change something to prevent it. |
31-03-2008, 11:48 PM | #11 | ||
Yeh, the worst time for it to happen is when your far from home. Trust me, its not fun nursing your car a good couple amount kms...
01-04-2008, 12:16 AM | #12 | ||
and even worse is when ur far away from home and its midnite....and wats worse than that is ur mobile fone is close to dying, bu ttheres still hope that u can msg sumone and wat do u realise u have no credit. :(:(
anyways im gona get it checked, coz as u can see above ive had similar problems before... i live in the oakleigh area, and near dandenong (in melb ofcourse) do u guys know of any good mechanics around there.. thanks |
01-04-2008, 09:12 AM | #13 | ||
Walking with God
I'd just drive around for a few days and see how it goes.
It may be as simple as the ECU needing a reset. GK
