Hardcore I6 Enthusiast
Wish me luck guys!
Ive currently got a mandrel bent 2.5 inch exhaust with standard muffler and resonator and a high flow stainless cat. Pumping the gasses out are some pacey comp's! It sounds stock with a tiny deep note at the moment because of the standard bits and pieces filtering the air. Tomorow it gets a lukey straight through and a hot dog instead of a resonator hehe. Should be a drastic change in sound! Will post sound vid up when its done, cant wait! So in full, pacey comps --> High flow stainless cat --> lukey straight through --> hot dog :evil3:
2002 AU XR6 VCT III 'ST' Liquid Silver Auto Full Momo and Leather Trim. Redback exhaust, high flow cat and Pacey Extractors. SELLING MY GENUINE 18" AZZUROS WITH TYRES. FRONT TYRES 95% REAR TYRES 50% |
if you can you should get a straight thru un perforated resonator instead of a hotdog, hotdogs are rather restrictive.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm. |
how about the noise with the resa compare to the hotdog?
quieter and deeper, and will have more of a note to it and less drone.
The rear straight thru non perforated resonator is basically a small glass packed straight thru muffler, and with mufflers the further they are put to the rear of the car the more drone/constant sound they remove cause their is less pipe after them for the sound to echo in. And flow wise a hotdog in 2.5inch flows 280cfm from memory, and a non perforated resonator flows around 500cfm, depending on brand etc.
