Old 24-06-2009, 05:27 PM   #1
EVL BOS
EVL BOS's Avatar
Default au auto leaking
hi i was just wondering if anyone has had this problem, the auto in my au1 is leaking from the back of the sump, i've taken it to my mechanic and he's cleaned around the area and tightened the bolts on the sump, but it's still leaking, doesn't look like is coming from the rear tail shaft seal as there's no oil around it. but he said it could be coming from the breather at the top, it only leaks when i turn the car off and it sits for a few-minutes then it oil starts dripping but only for a little bit then stops, im going to take it back to my mechanics tomorrow so he can look at it.
cheers
Daily: UA11 BiTurbo Everest
Weekend Project 1999 AU XR8
Past rides:
Mondeo XR5 Turbo
RIP: FGX XR8 MANUAL Build Thread:
http://fordforums.com.au/showthread.php?t=11447239
AU Fairlane Sparkling Burgundy thread:
http://fordforums.com.au/showthread....61#post5854961
UX explorer limited
FOCUS ST,
UT Explorer limited Written OFF
BA XR8
Build Thread:
http://fordforums.com.au/showthread....1299363&page=7
AU XR6 VCT
ED GLI Classic
EVL BOS is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2009, 06:38 PM   #2
sbcb
BA Xr8
sbcb's Avatar
Ive had a leak from the auto pan gasket before which was a simple & cheap replace.
sbcb is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2009, 10:13 PM   #3
AUbigfoot
Ford beginner
AUbigfoot's Avatar
I had a very similar problem. Turned out to be cracked/broken seals. Replace the cheap rubber ones with some copper ones. It's a good start at least.
2002 Series 3 AU Fairmont
aufalcon.com/bigfoot
Build thread:here
AUbigfoot is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2009, 10:38 AM   #4
EVL BOS
EVL BOS's Avatar
dont think its that cause i had the auto serviced 12000km's ago, but thanks i wish was that easy and cheap.
Past rides:
Mondeo XR5 Turbo
UX explorer limited
FOCUS ST,
BA XR8
Build Thread:
AU XR6 VCT
ED GLI Classic
Old 25-06-2009, 01:35 PM   #5
Dauphin
Irregular member
Dauphin's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Endless work keeping the AU.com.au web site happening
I had the same problem, turned out to be a gasket that needed replacing.
2000 AU II FAIRLANE 75th ANNIVERSARY - big and shiny
My hovercraft is full of eels!
Movie Car Chase of the Week: Gene Hackman driving a 1971 Pontiac LeMans to chase an elevated train in The French Connection (1971).
Dauphin is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2009, 01:48 PM   #6
RG
Back to Le Frenchy
RG's Avatar
What's the bet that they've tightened the bolts a little too much. This flattens the pan and then no matter what you can't get a good seal, by re-tightening the bolts he has just made it worse. I've had this happen to mine before that the only real fix is a new pan. Thankfully these are pretty inexpensive.
Originally Posted by drew`SEVNT5
nah mate, aussie cars are the besterest and funnerest, nothing beats them, specially a poofy wrong wheel drive
RG is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2009, 01:53 PM   #7
Dauphin
Irregular member
Dauphin's Avatar
RG, I think this is exactly what happened with mine. The mechanic struggled for ages to undo the bolts and said that Superman must have done them up. He was having a really hard time. A reputable Ford dealer may have done it.
Old 25-06-2009, 04:57 PM   #8
EVL BOS
EVL BOS's Avatar
just got back from my mechanics, turns out it was the oring around the servo was stuffed so its been replaced and hopefully that fixes the problem :
Past rides:
Mondeo XR5 Turbo
UX explorer limited
FOCUS ST,
BA XR8
Build Thread:
AU XR6 VCT
ED GLI Classic
Old 26-06-2009, 12:53 AM   #9
mik
mik's Avatar
you can straighten the pan rails while its resting on a block of wood or something similar out, usually a few hits with the persuader will do it, never found a metal one that could`nt be fixed.
