08-10-2009, 11:54 AM | #1 | ||
Hi everyone,
just wanna get an opinion on getting a car custom tuned. I wanna get my AU XR8 220kw custom tuned. However, the only fuel supply i can access is 95 octane... I have been informed by a pretty well known person, but will not mention names that getting a tune done with 95 octane is crap.... And that i will only gain 5kws at most from a custom tune. Has anybody had there car tuned on 95 before? I dont car what model AU, BA, FG, V8 or I6... What results have you gained with a custom tune on 95 octane.... Cheers |
08-10-2009, 05:30 PM | #2 | |||
AU DIE HARD
220 s are 95 tuned from the factory,with a custom tune unless you have other mods IMO be a waste of time most of the gain from 98 ron is had through Timing advance. although you could add a bottle of octane boost and reset your flash box with a separate tune. : Just a thought
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... .................................................. Quote:
08-10-2009, 05:32 PM | #3 | ||
not here much anymore
Will disgaree here and say that for the tune you should go with the fuel you use and have access to the most. I tuned my old AU on 95RON as it is what I ran in it 99% of the time because at that time the supply of 98RON could not always be guaranteed here, I can't remember the exact numbers before and after the tune but there was still a noticable difference.
As with all tuning you should not be concerned with numbers but rather how the car behaves and drives before and after - that is how I measure how 'good' a tune really is.
2024 F150 XLT
08-10-2009, 05:52 PM | #4 | |||
08-10-2009, 08:02 PM | #5 | ||
a custom tune sometimes wont bring your peak kw up by much but you would probably notice a big improvement throughout the rev range, probably have a lot more lower rpm pickup
even if they say its tuned to 95ron factory, remember the factory tune is a very very safe tune! there would still be room to advance the timing and youd get more power from an improved air/fuel ratio good luck with it anyway, will be great to see how you go
Current Blueprint 03 xr8 5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives 256rwkw BA manual Typhoon Fully optioned, 340rwkw@16psi (thanks Bluepower)! The old ride.... AU Fairmont, cammed beast, R.I.P you made my p plate years bearable! 150.8rwkw courtesy BPR |
08-10-2009, 09:05 PM | #6 | ||
Cat be Still !!!
There is no room to advance timing on a 220 they have a heap stock. If you go to a tuner and he says he's going to put timing in, walk away because it will ping its nut off and probably burn a piston if ignored.
Mine has had timing pulled out, You get gains from pulling fuel out because from stock they run very rich from around three grand and most end up with AFR's in the tens. Now my AFR's start at 13.5 from 1500rpm and and run along at about 12.8 all the way from 3000rpm to 5600rpm. Cheers, Craig. Last edited by CRAIGAU3220; 08-10-2009 at 09:11 PM. |
08-10-2009, 09:11 PM | #7 | |||
Mine did run very rich for the brief time it was in stock form - it had a Unichip when I bought it and over time that deteriorated to the point where I had to return it back to stock - I could not believe how rich it ran, black buildup on the exhaust, smelt of fuel etc etc. The tune certainly fixed that.
2024 F150 XLT
08-10-2009, 09:56 PM | #8 | |||
i suppose its tuned up a bit from the 200kw anyway?
08-10-2009, 10:41 PM | #9 | ||
Cat be Still !!!
Hey Stattic, No probs. Not long after i got my car i went to Chiptorque for a power run just to see what it had atw and see were the AFR's where at, anyway as expected AFR ran in the 10s after four grand, Now this bloke said that Tickford put alot of timing in the 220s and alot of fuel so there is power to be had by pulling fuel but you must pull timing out first, now this guy was a Ford man but had turned to the dark side and only tuned Holden's when i went there. A few months later i got a custom tune at a well known Ford specialist and they put timing in and pulled fuel out so no long after i was back there because of detonation.....And to cut a very long story short about twelve months later i went to Xtreme ford tuning and got a good tune with plenty of power and now Dramas.
Cheers, Craig. |
08-10-2009, 11:06 PM | #10 | |||
Now Fordless
09-10-2009, 01:03 AM | #11 | |||
Cat be Still !!!
09-10-2009, 03:28 PM | #13 | ||
Cat be Still !!!
Yes, John all the time.
