Old 02-09-2005, 08:40 PM   #1
harry
harry's Avatar
Smile Take Offs
im wondering how you guys do your take offs from lights etc??
i had some fun with a Turbs tonight and my take off was fine until it it about 4000 rpm when the wheels started to spin so i popped it into second and it went saide wayz.
When would you change into second??
i wouldve thought bout redline but its pointless spinning the wheels while trying to play!
harry is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2005, 08:43 PM   #2
ilsautomotive
Former E-Series Member
I presume the story you tell is from a drag strip or a private road.
The gear change point would vary depending on the transmission ratios, cam and other variables. The best way is to go to the drag strip and compare times with different launch techniques and gear change points.
ilsautomotive is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2005, 10:40 PM   #3
347Stroker
347Stroker's Avatar
If the wheels are spinning, shift up, no point losing traction. Use the engines torque.
347Stroker is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2005, 11:27 PM   #4
GreenMachine
Mopar/No Car
GreenMachine's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Sensational write up about drum brakes.
If the wheels are spinning, give it ********!
ColumnShift Media
'72 Plymouth Scamp
'80 Courier
'13 Kawasaki ZX14-R
'13 Berlina
'92 Suzuki DR650
If you don't fight - You lose
GreenMachine is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2005, 11:33 PM   #5
K1W1 Dave
Still alive & kicking
K1W1 Dave's Avatar
My EL XR8 is a auto and it seems to get off the line pretty good
I always start in second have been playing around with rear shocks
you can loose alot of traction by having your rear end to stiff
EL XR8 made to burn rubber
:evilsasmo IN THE BEGINING THERE WAS TICKFORD
K1W1 Dave is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2005, 11:50 PM   #6
GreenMachine
Mopar/No Car
Nothing like a good stiff rear end...
ColumnShift Media
'72 Plymouth Scamp
'80 Courier
'13 Kawasaki ZX14-R
'13 Berlina
'92 Suzuki DR650
Old 02-09-2005, 11:51 PM   #7
347Stroker
347Stroker's Avatar
Jeezorz, nothing stiff gets near my rear end.....
Old 03-09-2005, 12:33 AM   #8
Biggoggs
Rider on the storm
Put it this way, if your wheels are spinning, it means your tires can't put power down to the road. Your tires loose traction up high because that's where the power is. Find where you start to lose traction and back off a little.
Not sure what sort of Falcon you have, but an EA (3.9mpi) makes 338Nm @ 3500rpm and 139kW at 4250rpm. An EF six makes 357Nm @ 3000rpm and 157kW @ 4900rpm.
Correct me if my technique is wrong, but ideally you should take off with the engine at max torque and generally keep the revs between those areas, without too much wheelspin preferably
Biggoggs is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2005, 01:17 AM   #9
Clarke AV
OzECruisers Treasurer
Clarke AV's Avatar
YES you got it
Clarke AV is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2005, 08:19 AM   #10
NIGHTHAWK
starter motor
NIGHTHAWK's Avatar
Cool
I would change into second, 1 before you red line it in first,2 before doing any damage to the engine or drivetrain and or being a nuisance to any other road users.
NIGHTHAWK is offline   Reply With Quote Multi-Quote with this Post
