Old 12-03-2010, 12:05 PM   #31
Road_Warrior
Pity the fool
Road_Warrior's Avatar
Originally Posted by Raptor
How about VW groups W12 ;)
Similar size to a V6 but with 12 cylinders :
That engine still makes my head explode, I can't comprehend the concept of a W motor or even how it works.
Fords I own or have owned:
1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD
Proud to buy Australian and support Ford Australia through thick and thin
Road_Warrior is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2010, 12:23 PM   #32
gunner
The "W" is a bit of a misnomer and probably causes peoples' confusion. Think of the W12 as a normal V12 engine ie two inline 6 engines connected at the crank. The only difference is that VW didn't use two inline 6 engines, they used two VR6 engines.
So what's a VR6 engine? It's a very, very narrow angled V6 engine. On a normal V6 you have two separate cylinder heads. Now imagine a normal "V" angle is 90 degrees. What happens when you start reducing this angle? At 45 degree, say, you'd still have two separate cylinder heads but if you reduce the angle further the cylinder heads will eventually touch. So VW basically just made a very, very narrow V6 engine that had both its cylinder heads connected into one.
Hope that made sense...
Otherwise:
VR6 Engine
and
W12 Engines
gunner is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2010, 12:25 PM   #33
Kamshaaft
Broken eBay Starter Motor
The conrods come in at slightly shallower angles for the lower banks of cylinders and IIRC the two cylinders that are paired together fire at different points in the firing cycle. It's a neat piece of engineering to get it to run as well as they have, but it's still bound to be less smooth than the Barra, or a Jag V12, or etc.
I don't know what the firing order is though. I'd hate to have to put a new dizzy in, as everything would be in Italian. If it came from VW in German, I might be safe.
Kamshaaft is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2010, 06:55 PM   #34
geckoGT
Ich bin ein auslander
geckoGT's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always level headed and i notice him being the voice of reason when a thread may be getting heated
Its german for a start, and as if it is going to have a dizzy.
Growing old is compulsory, growing up is optional!
geckoGT is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2010, 07:19 PM   #35
CPOCSM
Here is an Alfa with a straight 8
http://www.youtube.com/watch?v=9UyChWMbl_A
Bloody awesome noise!!
CPOCSM is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2010, 07:29 PM   #36
Kamshaaft
You got me.
Figure of speech.
Old 12-03-2010, 07:32 PM   #37
Yaw
Ford Fanatic
Yaw's Avatar
Probably a bit late in the thread for this, but anyway.
The car that Duston Hoffman was rabbiting on about in "rainman" was a straight 8
1949 Buick Roadmaster. Straight 8. Fireball 8.
Everyone is entitled to my Opinion
2007 Territory TX SY RWD Ego
Yaw is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2010, 08:41 PM   #38
joolz
My Grandfather used to work on them years ago and were common for breaking cranks as they were so long.
joolz is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2010, 08:44 PM   #39
Franco Cozzo
Franco Cozzo's Avatar
With the breaking crank issues, couldn't you just make them out of a stronger material? I'd imagine it'd be a similar issue the 20B rotory engine has, they have problems with snapping their eccentric shaft when you start hitting certain power/torque figures which can be resolved by spending up on better quality stuff.
Old 12-03-2010, 09:04 PM   #40
Wally
XP Coupe
Originally Posted by Big Damo
I was just thinking the other day, we've got an I6 right? Why don't we have I8s? Obviously it isn't just going to be as easy as slap on an extra 2 cylinders but how come we don't have them?
I'm guessing it would be a tad bit too long, but would it offer any benefit over a V configuration?
I must be getting bloody old, because it used to be common knowledge why the V8, but for the youngsters: the longer the crankshaft the more prone it is to whip at high revs. Not an unknown phenomenon even in today's supa dupa I6's. Having said that, common knowledge in auto circles is usually baseless.
Wally is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2010, 09:14 PM   #41
Road_Warrior
Pity the fool
Well, I'm sure back in the day when straight 8's were all the rage they could have made the cranks out of a stronger material, if it existed then and if the know how existed along with it.
Old 12-03-2010, 09:44 PM   #42
jpd80
jpd80's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Thoughtful contributions to our community
Originally Posted by melon466
5 cylinder is the best balanced engine you can get
Far from it, they have terrible NVH.
I-6, V12 and horizontally opposed engines are the best balanced engines.
jpd80 is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2010, 06:36 AM   #43
The Yeti
The Yeti's Avatar
Originally Posted by cosmo20btt
From what I remember straight eights had a common problem of breaking cranks, that is one of the reasons v8s replaced them.
thats not entierly true, braking cranks isnt a real issue this can be adressed with adding extra main bearings but the reason was simply real estate, to get cubic inches you need bore size X stroke so to get the size engine you eaither had a really long bonnet or went wit ha V configuration
theres still plenty of healthy straight 8's arround in the nostalgia seen
pitty classics.com are such tools about posting images on other forums perhaps if they did more people would see the image and follow it through to find more and they would get more traffic :
Pariahs C.C.
What could possibly go wrong
I post images with postimg.cc (so I don’t forget)
The Yeti is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2010, 03:19 PM   #44
buggo
[BU66OS]
buggo's Avatar
XR5 owner/fanboy?
FG XR6 Turbo Nitro
BA XR8 Manual
buggo is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2010, 11:46 AM   #45
Quicksand
Lucky, lucky bastard!
Quicksand's Avatar
That sounds HOT AS!!!
2015 Mondeo Trend 2.0T Diesel, Deep Impact Blue
2012 FPV GT-P 6spd Auto, Lightning Strike
Quicksand is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2010, 12:13 PM   #46
aussie muscle
aussie muscle's Avatar
Originally Posted by lofty
What I want to know is, is it theoretically possible to design a V8 crank to replicate the balance factors of a straight 8? In case that makes no sense, consider that you can make a parallel twin sound and feel like a 90 deg V twin by phasing the big end journals 90 deg apart. Yamaha did it with the TDM and TRX. So why wouldn't the reverse be possible, giving the character of a straight motor with the benefits of a V?
There's a bit of that stuff in the last Australian Muscle Cars magazine about the old F5000 engines. relating to how the angle of the big ends and crank were made in them.
as for straight 8's, it helps when you have a bonnet longer than half the car's length, like a Cord or Dusenburg. :
My ride: 2007 Falcon Ute BF XR8 Orange, MTO.
aussie muscle is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2010, 06:50 PM   #47
[CaSeY]
who cares about a straight 8, how bout barra v12 with 2 turbos
[CaSeY] is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2010, 07:11 PM   #48
jpd80
jpd80's Avatar
What you're suggesting is a flat plane crank, beautiful balance
and no counter weights required on the crank...
Sounds like two four cylinders, check out the Ferrari:...LINK
Old 15-03-2010, 07:12 PM   #49
388cube_edxr8
Nutty Professor
388cube_edxr8's Avatar
Waaaaay ahead of you mate - already got one in the works. The hardest part is finding the money to fabricate the crank and the passenger side head (manifolds are on the other side)
Should have about 700kw (960hp) when done but its a loooong way off.
Originally Posted by Jeremy Clarkson
If you buy a rubbish car, what you are saying is "I have no interest in cars." If you have no interest in cars, you have no interest in driving, and if you have no interest in something, it means you're no good at it, which means you must have your driving license taken away.
388cube_edxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2010, 07:16 PM   #50
Stattic
Stattic's Avatar
what lol have you got a link to a build thread or something or are you joking
Current
Blueprint 03 xr8
5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives
256rwkw
BA manual Typhoon
Fully optioned, 340rwkw@16psi (thanks Bluepower)!
The old ride....
AU Fairmont, cammed beast, R.I.P you made my p plate years bearable!
150.8rwkw courtesy BPR
Stattic is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2010, 09:40 PM   #51
388cube_edxr8
Nutty Professor
Nah mate serious but suffering from a severe lack of funds. I need to spend more time at work and less time in the shed.
Old 15-03-2010, 10:21 PM   #52
Saraco
Saraco's Avatar
And YAMAHA have done it again! The new R1(2010 MODEL) is an inline 4cyl but has a 90 degree i.e. two plane crank (all other inline 4cylinders have a single plane 180 degree crank) this thing is the most V8 like sounding inline 4 I have ever heard! Sounds even more V8 like than a V4!
Saraco is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2010, 06:06 AM   #53
The Yeti
The Yeti's Avatar
a mate of mine owns Pauls Old Skool Only, he's currently doign a hart transplant on an old Buick
theres plenty more here if you are interested http://www.facebook.com/?ref=home#!/album.php?aid=197364&id=334269315675
http://oldskoolonly.com/default1.htm%20index1.htm
Pariahs C.C.
Old 16-03-2010, 11:54 AM   #54
lofty
Rusticating
lofty's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent article on AU Power window installation.
Meaning what, replacing the I8 with a V8? If so, what's happening to the oldie?
Territory SYII RWD, BFII RTV tray
lofty is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2010, 11:58 AM   #55
lofty
Rusticating
lofty's Avatar
Waaaaay ahead of you mate - already got one in the works. The hardest part is finding the money to fabricate the crank and the passenger side head (manifolds are on the other side).
Casting up a V12 block no biggie then?
