Old 08-05-2013, 03:40 PM   #1
david lee
Default au keyless remote
can anyone give me some advice why my remote sometimes works and sometimes dosent even with a new battery.sometimes you can hold the buttons down and the red light wont flash and other times will. thanks
david lee is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2013, 04:17 PM   #2
MrEL
Sick Puppy
MrEL's Avatar
Default Re: au keyless remote
The solder where the battery cradle attaches to the circuit board will be cracked.
Common problem. New remote time.
MrEL is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2013, 08:48 PM   #3
david lee
your right the battery cradle is detatched from circuit board. thanks bud
Old 09-05-2013, 07:12 AM   #4
FGX-351
Supercharged Mang-mobile
FGX-351's Avatar
What I did with mine(EL but i'm going to assume they're similar) is fold up abit of paper or cardboard into a small square and stick it behind the positive terminal to make sure the battery stays secure againts the terminal.
Contact points could also be dirty so a rub with a cotton bud dipped in metho(or even just a dry cotton bud) will clean any built up grime off.
Another thing you can do is fold up a some paper or cardboard into a small square and place it underneath the buttons to make pressing/contact abit easier.
All these things helped me with the reliability of my smart lock remotes, hope it can be of help to you.
09/00 VX HSV XU6 Build #0001 of 0171
http://fordforums.com.au/showthread....09#post5571209
-- Best E/T: |14.982 @92.12mph | R/T:0.013 | 60' 2.213| 330: 6.283 | 1/8: 9.624 @ 73.17mph | 1000: 12.529 | 25Deg, N/A Hum, 1010mb | Willowbank Raceway 7/12/16
Tickford EL Falcon XR6 RIP
-- Factory Manual
-- Best E/T: |14.991 @ 92.71mph | R/T: 0.607 | 60': 2.215 | 660': 9.665 |13Deg, 86%H, 1024mb, 184RA @ Willowbank Raceway
FGX-351 is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2013, 01:41 PM   #5
redxm
64 Deluxe 4 door
redxm's Avatar
you can solder the battery contact back in. Ive done it dozens of times. Ive even replaced faulty switches.
OP > Where are you located?
XM Deluxe
FG XR50
BA Pursuit Ute
redxm is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2013, 07:05 PM   #6
david lee
im in earlwood sydney how hard is it to solder. thanks
Old 09-05-2013, 07:11 PM   #7
redxm
64 Deluxe 4 door
redxm's Avatar
you need an iron with a fine tip, so you can get it between the battery carrier and the pcb.
if you think its too hard, post it up to me and I'll do it for you.
XM Deluxe
FG XR50
BA Pursuit Ute
Old 10-05-2013, 07:42 PM   #8
david lee
a mate has one to do the job. thanks
Old 18-05-2013, 11:28 PM   #9
ashebxr8
ashebxr8's Avatar
Just another question. Will a series two SEDAN keyless remote work on a series two UTE.
ashebxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2013, 08:38 AM   #10
redxm
64 Deluxe 4 door
redxm's Avatar
yep. boot release wont work but.....
just code it as normal
XM Deluxe
FG XR50
BA Pursuit Ute
Old 19-05-2013, 09:46 AM   #11
ashebxr8
ashebxr8's Avatar
No worries. Cheers for that.
Old 16-08-2013, 04:01 PM   #12
bs395
bs395's Avatar
i have a new remote for my ute, turn acc press demister 3 times doors wont acuate, any ideas, i have done this many times as well with nothing,
bs395 is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2013, 02:48 PM   #13
david lee
its a bit tricky my mechanic did it in 5 seconds
