Old 06-12-2014, 08:40 AM   #31
irvinnie
irvinnie's Avatar
Default Re: Mud flap removal and repair under warranty
My mud flaps had been removed and I had even put touch up paint over the marks to try and mask the damage. It was obvious what had caused the damage to the paint work, both sides of the ute tub area got re sprayed
Current rides
2014 FGX G6E Turbo Tuned by Walter@Oztek performance 504rwkw on e85/420rwkw on 98 with a PCMTec flex fuel tune
- 2010 FG GT (335 build #152) 437rwkw
- 2012 XR6 turbo Ute 345rwkw
- 2007 Force 6 (build #91) 330 rwkw
- 2010 GTE (build #2) 425rwkw
- 2010 50th anniversary turbo ute 365 rwkw
irvinnie is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2014, 10:22 PM   #32
Im definately gunna have a crack at them myself, if i get it good enough I'll b happy, hopefully..
Old 06-12-2014, 10:31 PM   #33
Silver Ghia
Silver Ghia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: As Silver Ghia his contributions to the AU and BA technical areas have been of high quality and valuable to the member base.
If Ford was serious about supplying a quality product in these mud spats, they would include in the mudspat kits Scotchgard anti-abrasive strips pre-cut to shape ready to install. And have these fitted under the rear spats on the ute from the factory.
After all these kits aren't all that cheap for a couple of moulded plastic spats and a few clips.
Silver Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2014, 05:59 PM   #34
superfly
Go the Hogster!
superfly's Avatar
I'm sure my rear mudflaps have some strips on it. I'm not sure of the front ones. I'll try and take some photos of it.
Nitro XR50 - the last brand new one in OZ
first registered Oct 2011.
superfly is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2014, 07:49 PM   #35
That'd be good
Old 10-12-2014, 01:13 PM   #36
superfly
Go the Hogster!
superfly's Avatar
Originally Posted by Lunch View Post
That'd be good
Sorry mate, I was wrong. There's nothing behind my rear mudflaps. I took a quick look if there was any damage but couldn't see any. Then again, it's pretty dirty behind the mudflaps. I will clean it up and stick in a piece of rubber on the bend. That should keep it away from the paint.
