Old 13-03-2006, 10:55 PM   #1
Crapozo
Default Basic car performance questions
Hello,
I just recently found a flash game on the internet called Drag Racer Version 3, and i find it quite interesting.
Anyway from playing the game i have found out a few things about manual cars which i have a few questions on:
1. You can change the gear setup (speed) with cars to give em more horsepower, torque etc...
How do you do this? I think for the newer cars you can do it digitally but how about older cars?
2. When you approach the red section of the RPM meter the temperature goes up dramatically. But what is it the actual temperature of? The petrol?
3.If the temperature goes too high, the car engine gets "blown". So what would this mean, in real life i would have to replace the entire engine? What is actually blown?
4.And is it possible to tune a automatic transmission too?
Crapozo is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2006, 10:58 PM   #2
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
Are you for real ?
1. Change the diff gears
2. Engine temp.
3. Engine has blown, yes same as real life, my advice is change gears just before the redline, not after it.
4. An auto trans can be kitted to shift harder and have a larger stall convertor to leave the line with more revs.
Falcon Coupe is online now   Reply With Quote Multi-Quote with this Post
Old 13-03-2006, 11:02 PM   #3
stiddy
stiddy's Avatar
hahahahahahahahahaha
stiddy is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2006, 11:17 PM   #4
Jim Beam
Oh he cant be for real...
Noone could be THAT dumb.
Oh and this is my first post, and for you Fordmods boys I'm also Jim Beam on there.
Jim Beam is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2006, 11:23 PM   #5
Falcon Coupe
Clevo Mafia Inc.
Give him a break, everyone learns at somestage, great first post ehh. :yeees:
Old 13-03-2006, 11:23 PM   #6
Crapozo
Yeah i'm for real, i know NOTHING about cars and just want to know alittle bit more about them
I know nothing about cars. Really!
I am here to learn
Old 13-03-2006, 11:24 PM   #7
GTS_300_Coupe
Mandy Moore FTW!
GTS_300_Coupe's Avatar
give the guy a break, not everybody is a car nerd around here.
GTS_300_Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2006, 12:33 AM   #8
stiddy
stiddy's Avatar
Welcome to the Forum matey..
Old 14-03-2006, 08:09 AM   #9
merlin
merlin's Avatar
6) If I use all my nitrous how long does it take to recharge?
7) I can't find the "speadbreaker" button on my corolla?
oh and welcome :-)
1966 Ford Mustang coupe. 347 stroker, PA reverse manual C4, TCE high stall converter, B&M Pro Ratchet, Edelbrock alum heads, Edelbrock intake manifold, MSD ignition, Holley Street HP 750 CFM carb, gilmer drive, wrapped Hooker Super Comp Headers, dual 3" straight through exhaust, Bilstein shocks, custom springs, full poly suspension, American Racing rims, Open Tracker roller spring saddles and shelby drop.
Still to go - Holley Sniper EFI with integrated fuel cell.
merlin is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2006, 08:20 AM   #10
agony
BLOWN 383 CHEV OWNER
at least your trying mate and got the guts to ask why things are going wrong, keep up the good work and you will work it all out there.
agony is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2006, 08:30 AM   #11
big_waity
Windsor Man!
big_waity's Avatar
Faclon Coupe pretty much answered them all. The only thing I would add is thatyou can also change the internal gearing of a gearbox. To do that, you need to replace all the gears within the box. A lot of work and not really worth the effort. It is MUCH harder than they make it look in Gran Turismo!
Wife's car - BA XT Wagon - Lowm shiney wheels, dark tint, no bottom half of front bar, faded paint :/
My Car - 93 Diesel Lux - not as fast but more reliable than her falcon!
big_waity is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2006, 11:38 AM   #12
pauljh74
pauljh74's Avatar
As for how to make an engine have different power/torque characteristics, things like camshaft configuration would influence that without going to complete engine rebuilds. The camshaft determines when and for how long the valves open and close. By putting a different camshaft in it can change the engine's nature - ie. instead of producing torque across a wider rev range, this powerband range can be reduced, but the peak performance may increase. The closer you push the engine to it's limits in it's setup to extract max performance, the more stress you put on it and the more likely it is going to go bang sooner rather than later. Car makers generally make the engines develop power over a wider range and set them up fairly conservatively to achieve the level of durability expected ie 200,000+kms under normal use.
Originally Posted by Mark Webber
Not bad for a #2 driver
Mark Webber after winning the 2010 British Grand Prix.
pauljh74 is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2006, 03:40 PM   #13
Crapozo
I thankyou for the replies,
I think in some of the questions my descriptions were alittle bit off what i meant was:
1. How do i tune the gears on a car? (not how to change the gears)
3. So if the engine is blown, what is actually wrong with it? would the whole engine need to be replaced?
I am here to learn
Old 15-03-2006, 03:47 PM   #14
foxtrot
Blood, sweat & tears
foxtrot's Avatar
This guy has to be joking
seriously...
2001 AUII SR 5 Speed
Liquid Silver
Inside:
Momo Gear Knob
Schmick Pioneer Headunit w/ Dolphinvision :
4 Channel Kicker Amp to decent speakers;
Alpine Monoblock to Pioneer Subwoofer;
Tuned to perfect clarity-
Outside:
Pure Sexy Falcon w/18" BA XR8 Factory Option Mags
Clear Side Indicators
Coming soon:
Pedders lowered Sports Ryders all 'round
Extractors/Exhaust/Hi-Flo Cat
foxtrot is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2006, 03:51 PM   #15
FRDXR6
FRDXR6's Avatar
1. Firstly could i ask what kind of car you have in mind when you ask these questions?
2. Secondly what do you intend to the use the car for? e.g will you drive it on the street or will it just be towed to a racetrack and only drive on there?
Without knowing this its very hard to answer your questions and give you advice!
Also im fairly sure you wont be able to change the gear ratio in any widely available gearbox for any street car. To do this i would assume you would need a fully adjustable tranny as found in race cars etc (are you willing to spend at an absolute minimum $10 000+ just for a gearbox?) Most people choose the gearbox according to the ratios, they dont muck around changing ratios once they have a gearbox. But someone maybe be able to correct me on this.
FRDXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2006, 03:54 PM   #16
big_waity
Windsor Man!
big_waity's Avatar
Hi mate, with your first question, what do you mean by tune the gears? Do you mean change the ratios? If you mean change the ratios, then you do need to replace the internal gears. Otherwise, I have no idea what you mean.
With your third question, it depends on what is blown. More often than not, cars blow head gaskets. A blown head gasket is pretty comon with E-Series sixes. Repairing a headgasket can be done by just replacing the headgasket, which is a little under a hundred bucks plus labour. To really do the job properly, you replace the headgasket, some bolts and some seals and you get the head checked. If the head is fine, you put it back on, if not, you get it machined or just replace it. So, you can be looking at anywhere between $300 and $3000 depending on the damage and how good a job you get done.
Old 15-03-2006, 04:03 PM   #17
big_waity
Windsor Man!
big_waity's Avatar
So, Crapozo, I don't want to sound rude or anything but, how old are you?
Old 15-03-2006, 10:41 PM   #18
Crapozo
yes yes i know my questions are kinda dumb but i seriously know zilch about cars
Anyway i am 20 years old
ok i think my questions confuse some of you, i know a way to make you all understand!
goto this address and play this game in tuner mode,
http://www.ebaumsworld.com/dragrace3.html
Now there is a tuning section where you can adjust the speed of the gears and when you drag race the car and the temperature gets up to 100, the engine "blows", this is what i mean.
I think the questions i ask should be possible in all cars
I am here to learn
Old 15-03-2006, 11:01 PM   #19
Scott
:nutsycuck
Scott is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2006, 12:39 AM   #20
LeMans
LeMans's Avatar
Crapozo,
Well done for taking the first steps into the world of the car enthusiast. Regardless of what some people may think, no one knows anything until they are taught.
There are a few concepts involved here that need more than a little while to grasp though, but since everyone has to start somewhere, then this is as good a place as any and better than most.
Lesson 1: A gear box is just a fancy set of levers. As you probably know, anyone can move a heavy weight if they were to use a long length of wood as a lever. How easily you move it depends on how close the pivoting point is to the weight. If it is very close to the weight, then you can move it easily but you won't move it far. If it is further from the weight, then you can move it further, but you will need to use more force to move it.
In a gear box, each gear is just a round lever. Some gears let you move the car more easily (low gears) and others allow you to travel further (high gears). However, each gear is a permanent lever and these levers might not be the ideal compromise of distance and force for what you want to do (drag race). By replacing the gears in the gear box however, you can find a different compromise. Each compromise will have a different effect on the car depending on the power of the engine, the weight of the car and the length and grip of the race track.
This is why you are able to change the performance of the car by "tuning" the gear box, and by tuning I mean replace the gears.
Lesson 2:
Blowing the engine can mean many things and can be caused by many things. The game that you are playing has a very simple opinion of what blows an engine. Although overheating can cause an engine to blow, it is probably not likely that it will do so as it is shown in the game, although the engine will blow up as shown in the game for an entirely different reason... usually because the engine is spinning so fast that a component spins itself straight out of the side of the engine, or because the igniting petrol in the engine is just too big an explosion for the components to handle, so it blows up like a small bomb.
These are some very simple explanations, but as I said, a complex concept starts with a simple understanding.
LeMans is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2006, 08:29 PM   #21
Crapozo
Ok thankyou for all your replies,
I understand everything now
I am here to learn
Old 18-03-2006, 08:38 PM   #22
Laminge
Cuban... nothing like it
Hey Crapozo, welcome to the forums, what state are you in?
Originally Posted by Laminge
...its amazing how mud sticks to ones shoes, as flies do to the elderly and bottle blondes around fame and fortune...
Laminge is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2006, 08:45 PM   #23
WILDTRAKPX2
WILDTRAKPX2's Avatar
A dazed state... :
Just jokin
WILDTRAKPX2 is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2006, 07:03 PM   #24
Crapozo
Sydney, NSW
Too many girls to look at to bother with cars :P
I am here to learn
Old 19-03-2006, 07:24 PM   #25
[Tonko]
What's green is gold
[Tonko]'s Avatar
Sydney, NSW
the only problem with that is u can only LOOK, u have a nice car theres alot more u can do : only jokin with ya...
but seriously, good on ya for asking, we all had to learn sumwhere
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU -
1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps-
[Tonko] is offline   Reply With Quote Multi-Quote with this Post
