Old 03-07-2018, 03:27 PM   #1
Ford guru
Default Ford oil Filters- no Drain back valve
Recently changed filter on Mondeo Ma series Duratec 2.3 litre HE engine.
I inspected oil filter and realised it had no Anti drain back valve!
So after cutting filter open I had close inspection,no anti drain back valve so thought being motorcraft fords own it actually from dealer and as always I notice there made in Thailand. I think it already cheap labour to make and slice off a bit more cost and don’t put anti drain back valve. So I buy a Ryco synthetic premium one just to compare and the Ryco have much better filter element I got the one with synthetic suppose to be better and has silicon Anti drain valve and thicker metal body made stronger to go 15000km services it says. I using Ryco for now on!! Also buy a cooper oil filter by wix apparently owned by Ryco and wix cheaper than the other 2 seem well made and has synthetic anti drain back valve! Why would you go to the dealer to buy motorcraft.
Ford guru is offline   Reply With Quote Multi-Quote with this Post
Old 03-07-2018, 08:12 PM   #2
GASWAGON
Default Re: Ford oil Filters- no Drain back valve
Good filter testing there mate.
Ye i prefer to pay a bit more for Ryco or Coopers with the anti drain back valve too!
GASWAGON is offline   Reply With Quote Multi-Quote with this Post
Old 03-07-2018, 08:26 PM   #3
Crazy Dazz
I always buy Ryco.
Always have.
Old 03-07-2018, 09:11 PM   #4
Sar4890
Sar4890's Avatar
Same never had any dramas with Ryco.
Sar4890 is offline   Reply With Quote Multi-Quote with this Post
Old 03-07-2018, 09:50 PM   #5
jakkes
jakkes's Avatar
depends on the filters part number i got my motorcraft 6 pack of filter's for my ba 5.4ltr off amazon USA $5 each per filter and they have a very thick & sturdy anti drain back valve way better than the ryco's iv used on other cars previously
GIMME FUEL, GIMME FIRE, GIMME THAT WHICH I DESIRE.
BA falcon XT mkII, 5.4lt, 5sp,
Y-code, xy windowless pano, 3 on the tree manual.
re-shelled xy falcon GT, manual.
1980 honda CX500 scrambler/dirt tracker
jakkes is offline   Reply With Quote Multi-Quote with this Post
Old 03-07-2018, 09:59 PM   #6
Sar4890
Sar4890's Avatar
I suppose i only use Z9's and Z418's and have found the Rycos good i havent used motorcraft ones since the cars came out of warranty.
Old 04-07-2018, 10:14 AM   #7
madmurf
Is that the Motorcraft F1AZ6731BD ?
madmurf is offline   Reply With Quote Multi-Quote with this Post
