Old 04-07-2018, 07:49 PM   #31
burnz
VFII SS UTE
burnz's Avatar
Default Re: What's the worse factory calibrated speedo you've come across?
Originally Posted by davenl5l View Post
Every car I'm stuck behind on sa country roads
only on a single lane road, different story on a duel lane road..
I don't often hear the sound of a screaming LSX.
But when I do, So do the neighbours..
GO SOUTHS
burnz is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2018, 07:51 PM   #32
au350hp
Originally Posted by jpblue1000 View Post
No speedometer can be 100% accurate all the time. A typical tyre has 2-3% diameter through tread wear over its life. Manufacturers opt for reading high, as too close to the actual and they may be liable for fines received etc.
JP
Its a shame the Police aren't a little more aware of this fact. It would save a lot of time & money wasted at court.
au350hp is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2018, 09:54 PM   #33
Nikked
Oo\===/oO
Nikked's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Long time member, loves Fords, sensible contributor and does some good and interesting posts.
Not sure I understand...of the police radar gets you doing 10km/h over, thats got nothing to do with the speedo reading higher then actual speed...
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 05-07-2018, 06:28 AM   #34
davenl5l
davenl5l's Avatar
No because most of them drive in the fast lane
clevo mafia (sadly sold) 351c xe manual (now with short shifting 5sp goodness) xc gs coupe project...hmm more clevo for me new daily 2005 ba sr
davenl5l is offline   Reply With Quote Multi-Quote with this Post
Old 05-07-2018, 04:21 PM   #35
burnz
VFII SS UTE
burnz's Avatar
exactly, the speedo don't work in the right lane..
drive faster..
GO SOUTHS
Old 05-07-2018, 04:30 PM   #36
jpd80
jpd80's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Thoughtful contributions to our community
From 2007, the rule has been 0 (dead on) to 10% fast +4kph
No speedo is permitted to read slower than actual speed.
jpd80 is offline   Reply With Quote Multi-Quote with this Post
Old 06-07-2018, 12:50 PM   #37
mick taylor
Originally Posted by 4stanger View Post
Yeah/Nah.
Could have a speedo issue, but it did read near enough correct speed under 100km/h, I did get done by the police radar in a built up area, doing 70 in a 60 and that was about what the speedo was reading at the time.
https://fordforums.com.au/showpost.p...6&postcount=31
Wheels magazine test back in 1977, was where I realized the toranas had a speedo issue in the higher speed regions, not just mine ; http://planetsoarer.com/ford/fast/page7.jpg
My SL/R5000 speedo was just as spot on as my HX Sandman both had 3.08 diff and 14in wheels and both valve bounced at 200KM/H with the stock engines.
If the Torana is running 13in wheels and 3.08 diff maybe it's to do with the selection of the speedo gear that in the gearbox, mine was a green one I believe.
Maybe they were putting in a 2.78 ratio speedo gear with 13in wheels with 3.08 diff, a white speedo gear I think 2.78 was.
Sure some speedos may of been wonky ones but I can not see why they would of been as the speedo would be just the same setup Torana or the big Holden, behind the face that you see.
All the LH-X Torana's my mates had speedos were fine at reading and they were driving flat out on the highway a lot of the time.
If you work out the % difference between 3.55, 3.36 3.08, 2.78, 2.60 and then look at the wheel and tyres differences 13in to 14in, well I am sure Holden just tossed in what ever will do, as such was no real big deal back in the days. you had a red and a pink and a green a blue a white speedo gears that i can remember that I have seen for the Aussie box.
mick taylor is offline   Reply With Quote Multi-Quote with this Post
Old 06-07-2018, 01:26 PM   #38
Vesper Martini
Vesper Martini's Avatar
No wonder I'm always being held up by Subaru's
MY SZII is bang on, but only after being fitted with slightly larger OD tyres
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 06-07-2018, 01:28 PM   #39
roKWiz
Cabover nut
roKWiz's Avatar
Back in the day my old HX Sandman was out by 10km/h, a HJ 10km/h out.
At present I have a 92 T3500 Mazda truck which over reads 10km/h as well but is matched by the fuel gauge that under reads by a quarter tank. At least I never run out of fuel.
Old 06-07-2018, 01:44 PM   #40
mick taylor
Yeah/Nah.
Holden's with stock 253 or 308 with 3.36 diff and 14in wheels could only do about 180KM/H flat out as the stock valve springs just went into valve bounce around 5000RPM and the 308 V8 with a 3.08 ratio diff could do 200KM/H with 14in wheels.
The Torana with 13in wheels and 2.78 diff is much the same gearing as it is with a 3.08 ratio and 14in wheels.
I have that old wheels test mag still, i bought that mag when it came out.
When i got my SL/R5000 it was around 1989 and it had 14in wheels put on it and a LSD 3.08 diff and she hit 5000rpm at 200KM/H because of valve bounce and the same was true with my Sandman with a 3.08 diff, so the speedos and tacho must of been not that bad.
You could rev them stock engines out to 5500rpm but in top gear i would say that with the time span at high revs the springs start to get a shimmy by then and they lose some more tension then, so they can not hold 5500rpm for long.
Old 06-07-2018, 01:58 PM   #41
mick taylor
What diff ratio and wheels and tyres ?
Here look at this HQ Holden service book i have says in mph
Tyre 6.95X14 and 3.08 diff ratio = 23mph @1000RPM
D70 X14 ' '= 23.2 mph ' '
F78 X14 ' '= 24 mph ' '
7.35X14 ' '= 23.4mph ' '
So tyres make a difference as well and all.
Old 06-07-2018, 03:16 PM   #42
Junkyard-Dog
*barks incessantly
Junkyard-Dog's Avatar
Looking back, my BA's speedo was fairly accurate. It used to tell me I was going 100km/h when I was going 97-98km/h with newish tyres.
Junkyard-Dog is offline   Reply With Quote Multi-Quote with this Post
Old 06-07-2018, 03:25 PM   #43
roKWiz
Cabover nut
roKWiz's Avatar
I had the Sandman standard GTS rally wheels and was later shod with ER 78 steels and 3.08 salisbury.
The HJ Kingswood 202 had same wheels and tyres and standard banjo diff.
They were always out by about 10km/h @ 100km.
Had a new WB van with the same misreading speedo.
