Old 02-12-2024, 10:12 AM   #2191
cs123
cs123's Avatar
I'm looking for a solution to the corroded Coolant bypass tubes on a AU Windsor.
Similar to these EB ones.
Is there a source for them or failing that, is there a workaround?
I love Holdens....
cs123 is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2024, 11:14 AM   #2192
GTLEGEND
Not aware, it had a part number of F8RE9D424AA. ill see if I can find anything but not aware at the moment.
Old 02-12-2024, 06:39 PM   #2193
v1rus
are the heater cores still available for FG's or do we have to go non genuine jayrad now?
anyone know the part number ?
v1rus is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2024, 09:27 PM   #2194
GTLEGEND
What model FG?
FG1 is obsolete BA18B539A, FG2 is still available BR2Z18B539AA.
Old 02-12-2024, 09:47 PM   #2195
v1rus
Mk1.. looks like jayrad it is thanks
Old 05-12-2024, 12:03 PM   #2196
Hey mate,
These eight bolts, they’re the self tapping type. What’s their availability status, price?
Old 05-12-2024, 01:33 PM   #2197
GTLEGEND
Originally Posted by Citroënbender View Post
Hey mate,
Can you see the bolts in the image below?
Old 05-12-2024, 03:16 PM   #2198
Is HM1 a bolt?
I’d think size is about M8x30mm, they’re a thread-forming trilobular bolt with probably a 10mm hex head.
Else it will likely be on the page that has the tub/sheetmetal elements.
Old 05-12-2024, 05:00 PM   #2199
GTLEGEND
Is HM1 a bolt?
HM1 Is described as a bolt and it says you need 4 of them?
Trying to find a pic but no luck.
No bolts in sheet metal section.
Old 05-12-2024, 08:55 PM   #2200
GTLEGEND
Is HM1 a bolt?
What about HS3? I am trying to get an image of one to compare.
If so they are available at $5 each.
Old 05-12-2024, 11:26 PM   #2201
For the coolant bypass tubes on a AU Windsor this may fit (ebay Motors USA) https://www.ebay.com/itm/18589516492...Bk9SR_zlqezyZA Especially if the part number is similar.
Old 09-12-2024, 09:36 PM   #2202
GTLEGEND
Is HM1 a bolt?
I am sure HS3 is what you need, can get $5 each.
This should be the right one?
Old 09-12-2024, 10:25 PM   #2203
Hi mate,
It’s going to be a couple of days until I can pull up the back of a tub liner and document what’s there. My vague memory from about 2018, was that it had TapTite bolts holding the metal down, very similar spec to the tailgate hinge bolts but possibly one size smaller. Definitely the ones affixing the liner to the metal were something like your image.
