Old 23-11-2006, 10:33 AM   #1
Franks
Default Will Fitting Turbo Spark Plugs Help The Regular Barra 182 Performance ?
Has anyone tried it ?
The regular Motorcraft plug for the Barra 182 engine is a platinum and has a 1.4mm gap.
The Turbo and LPG engines use a different heat range plug with a gap of 1.1mm.
I know this has been discussed before but if anyone has tried it, what were the results like ?
Better or worse ?
Franks is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2006, 10:34 AM   #2
LTDHO
The one and only
LTDHO's Avatar
I can't see any gain in performance at all.
Sorry Frank
Tuned by CVE Performance
Old 23-11-2006, 10:39 AM   #3
Franks
Thanks LTDHO.
So you have tried it or know someone that has ?
Old 23-11-2006, 11:25 AM   #4
ebxr8240
Performance moderator
ebxr8240's Avatar
They are generally colder and closer gap due to combustion pressure of turbo engine... Imo no gain... Unless there was issues with old plugs....
Daily driver GTE FG..
Old 23-11-2006, 11:28 AM   #5
Ruger
Bseries Moderator
Ruger's Avatar
I had colder plugs (NGK double platinum turbo plugs) fitted to mine for a while when i thought the ign system wa a touch weak for the twin throttle setup and definately went backwards.
Running stock spec brand new ngk's now much better.
Long Live the Rugerspeed Primer Destroyer!
Only those that attempt the absurd achieve the impossible.
Serviced and maintained by Mascot Auto Repairs
Ruger is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2006, 11:40 AM   #6
Franks
Thanks fellas, I thought as much but it's good to hear from someone that's tried it.
Old 23-11-2006, 11:41 AM   #7
Ruger
Bseries Moderator
Ruger's Avatar
Happy to help mate
