Old 04-05-2005, 12:32 PM   #1
ATX5
Default Injectors Rebuild?
Heard some unusual taping under the bonnet last night and found that one of my injectors in making a little too much noise. I did the old "ear against the screw driver end" trick and found that it was making an awful racket inside. So bad that i could feel it vibrate through the screw driver. Has anyone removed their injectors themselves. If so, how hard is it? I was quoted $220 - $250 r, r & r (remove, repair & replace) all four injectors. I think I could cut the price down a bit by removing them myself. Any info would be helpful.
Only cheap wine comes in 5 litres
ATX5 is offline   Reply With Quote Multi-Quote with this Post
Old 04-05-2005, 12:54 PM   #2
MITCHAY
lol your game. If it costs $220 to r, r&r then i could only imagine how much it would be to get new ones. Ill check my service manual for you and get back to ya.
MITCHAY is offline   Reply With Quote Multi-Quote with this Post
Old 04-05-2005, 03:03 PM   #3
ATX5
While your looking at your manual, can you have a look at where the fuel filter is located and how the hell you get it out. How much did your manual cost. I really want to get a service manual for all those nitty picky things.
Old 04-05-2005, 06:43 PM   #4
tx5
Posts: n/a
ahaahaha! atx5 i got the same problem still havent found mine!! : i know approx. how much they are at autobarn $40 for a copy or $100 for manufactures real version. the guy in autobarn told me check around the front but i cant see anything... :evilsasmo
Old 05-05-2005, 04:51 PM   #5
KiwiKev
Posts: n/a
In the TX5 its under the rear seat - try keeping a look out on ebay for a manual got mine pretty cheap there but they get snapped up :-) or try the local public libary - they have manuals --then just photo copy what ya need
Cheers Kev
Old 10-05-2005, 05:54 PM   #6
MITCHAY
To remove the injectors: 2.2l EFI
1 Depressurise fuel system
2 You have to remove the plenum chamber
3 Disconecting fuel supply hose from the pulsation damper and fuel return hose from fuel return pipe
4 Remove the bolts securing the fuel return pipe to inlet manifold.
5 Disconnect injector wiring connectors and pressure regulator vacuum hose
6 Remove the fuel rail retaining bolts and carefully withdraw the fuel rail and injectors from the inlet manifold.
7 Carefully remove injectors from the fuel rail.
Insatllation is reversal of dismantling. Replace the O rings with new ones for the injectors.
This is what the book says and i have no idea how you do it.
The fuel filter is behind the air intake pipe and ignition coil. Cant miss it its the only filter there near the passenger side .
To renew
1 Raise rear seat cushion and disconnect fuel pump wiring connectors
2 Start and run engine untill the engine stalls.
3 Switch ignition to off and reconnect the fuel pump wiring connector.
4 Disconnect the negative battery terminal
5 Disconnect the hoses from fuel filter.
6 Remove bolts retaining fuel filter and mounting bracket and remove both bracket and filter from car.
7 Loosen the fuel filter clamp bolt and remove the filter from bracket.
Install is reversal of dismantling. Make sure the hose with the 90degrees elbow is located at the top though. Secure the hoses with the retaining clamps
Good luck with it i hope it helps. I still not game to do anything myself though.
Old 12-05-2005, 12:11 PM   #7
ATX5
thanks heaps for the info, but I think i'll just pay someone to do it. To much to go wrong
Old 12-05-2005, 12:29 PM   #8
MITCHAY
Yeah i reckon aswell. After reading and typing it all Im like **** it as if anyone could be bothered doin this. I just wrote what the book said so if the books wrong the your screwed. Good luck with it
