08-12-2008, 02:02 PM | #1 | ||
THE Fairmont Ghia 75th
now i was thinking about getting the whiteline 30mm front sway bar but wanted to know if it will make much of a difference, what is the best way to go about it as i will do it while i have the car getting the suspension done.
Current Ride : AUII Fairmont Ghia : 75th Anniversary Limited Edition
Current Mods-HD Built Gearbox+(Mirror Polished, Modified Valve Body), 2500rpm Hi-Stall Convertor(TCE Custom Built), BIG Trans Cooler, Braided Lines/Speedflow Fittings, 2.5" Exhaust, Custom CAI, Detailed UnderCarriage, Custom SQ Stereo Install. My Ride My Build Thread |
08-12-2008, 02:20 PM | #2 | ||
Lets organise a group buy?! Im in
08-12-2008, 02:22 PM | #3 | ||
I'm in too, specifically adjustable ones for front and back
08-12-2008, 02:24 PM | #4 | ||
Mine would need to be a set for an au xr8 ute also?
08-12-2008, 02:31 PM | #5 | ||
Critical Thinker
Sway bars definitely make a noticeable improvement with keeping the handling flat when you exit a corner under power. Certainly advantageous in the twisties so there is less chance of fish tailing or understeer etc.
But be careful when going too big as this could induce oversteer which is also not good. If you can, invest on getting both front and rear sway bars. Combined with quality springs and better shocks, it makes for a pleasurable handling experience.
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
08-12-2008, 02:35 PM | #6 | ||
How does aftermarket strengh vs factory, cause mine has a factory front 29mm swaybar on it.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm. |
08-12-2008, 02:40 PM | #7 | |||
Critical Thinker
08-12-2008, 02:52 PM | #8 | ||
yeah i should think that there should be a group buy but not till after chrissy, i will definatly have to get front and rear but whats it like as i have IRS, anyone done this with their IRS car?
08-12-2008, 02:59 PM | #9 | ||
Do it makes a massive difference.
The Ghia is so stable in the front. As for the rear of it does it already have one. I looked into it on mine as I wanted that little bit more of an edge but there was 1 mm dif between what was on there and an after market 1 so I just couldn't see the advantage to it. Have a look at my workshop build and you will see the parts I used. The package I put together was worth its weight in gold. Handling was fantastic!!! Just ask anyone tryin to keep up with me through corners.....lol |
08-12-2008, 03:01 PM | #10 | ||
ah nice, ill check it out, cheers
08-12-2008, 03:21 PM | #11 | |||
Flairs - Truckers Delight
08-12-2008, 03:23 PM | #12 | ||
...lol
08-12-2008, 04:20 PM | #13 | |||
Critical Thinker
08-12-2008, 07:45 PM | #14 | ||
not here much anymore
FFS can we go easy on the group buys!
Whiteline do a number of different options and they're very reasonably priced (they're on the right side of $200). For AU utes you need to have the swaybar welded in at the rear as they dont come with one at the back from factory.
2024 F150 XLT
08-12-2008, 09:03 PM | #15 | |||
RIP...
Mine just bolted up.
. Oval Everywhere... |
08-12-2008, 09:51 PM | #16 | ||
Ah well there you go, a suspension place here reckoned Id have to weld it in to fit it.
2024 F150 XLT
08-12-2008, 09:55 PM | #17 | |||
Fiat POWAAH!
Holden: If you cant beat them, buy them. |
09-12-2008, 07:37 AM | #18 | |||
