08-12-2008, 11:28 PM | #1 | ||
Hi all, today i removed my fascia in my s1 xr6 to mount my headunit but once it was all put back together the vent control knob wouldn't work! That is, i cannot select which vent to let air out of. Air only comes out of the front window demister, no matter which setting i have it on. i.e. if i have face vents selected it will only come out of the front window demister... I've checked the knob itself and it isn't stripped... I'm baffled, any help would be greatly appreciated!
08-12-2008, 11:45 PM | #2 | ||
you have probably knocked a vacuum line off from inside, time to pull it off again and have a look, good luck
09-12-2008, 02:17 AM | #3 | ||
yep no vacuum to it and it defaults to demister for safety reasons.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm. |
09-12-2008, 11:44 AM | #4 | ||
Cheers guys, is there anyway around this? i think i found the vacuum line, it's the yellow tube right? But there is also a green tube there that isn't plugged into anything.. i'll take some pics later today and post them asap. Cheers
09-12-2008, 08:32 PM | #5 | ||
XR6T 400kw(well one day!)
I did a car a long time ago ( cant remember if it was my ED or not ).
Anyhow i remember there were letters on the vacuum switch/modulator which corresponded to the colours taped to the vacuum hoses. ( e.g y for yellow e.t.c. There should be something like that there any way.
If it Vibrates, rattles, squeaks or knocks - then it must be a Territory |
09-12-2008, 09:50 PM | #6 | ||
Not to worry guys, the problem was fixed when the car was turned on (engine running that is). What a relief.. Thanks for your help.
09-12-2008, 10:01 PM | #7 | |||
I was actually going to ask whether you had the car running, i thought mine was stuffed one day, it was the same thing. No car running, no a/c out vents no vaccum to change vent position
Nathan 2005 FPV BF Super Pursuit The new toy (now sold) The SP The old ute (sold) www.aufalcon.com/nc1183 Build Thread Quote:
