22-01-2009, 07:19 AM | #1 | ||
Sales Representative
Are BA doors the same as AU doors? i'm refering to just the shell side of things, with the window glass, door hinges, power window regulators etc...
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! |
22-01-2009, 10:31 AM | #2 | ||
The shell is the same, apparently a lot of cabbies grab AU doors to replace theirs if they get damaged. Cheaper than BA doors I'd assume, but fits in no worries.
05 BF XR6 ZF 6spd - Stock for now Previously: 98 AU Futura 4.0 - Wildcat Extractors, 200cpsi Stainless Cat, Custom 2.5" Mandrel Bent Exhaust, Tickford Snorkel, Fram 'Airhog' Panel Filter - Daily
79 P6 LTD Silver Monarch - Project |
22-01-2009, 04:50 PM | #3 | |||
22-01-2009, 05:19 PM | #4 | ||
That would be my assumption, I'm not sure about the latches, because I know they fiddled around with them in the BA, but they're also probably interchangable.
22-01-2009, 05:45 PM | #5 | ||
Ford Owner
I know the door actuators they sell now are fron BA for the AU so they fit if that helps, they are also sposed to be better and not them selves as much, ive been through 3 already lol.
22-01-2009, 06:29 PM | #6 | |||
22-01-2009, 09:34 PM | #7 | ||
i think you'll find the crease line is the same, but the side trim is different. easy enough to change tho.
I would guess the door handle is the same as there was no need to reengineer it.
Shed cleanout.. Pictures and prices here Dynamat type product Group Buy Here(Round 2) |
22-01-2009, 09:58 PM | #8 | ||
I have put AU doors on BA taxis
Externally the same except for the plastic stripe, but the holes are the same so simply put your BA stripe on, lots of fun getting off that tape On the inside the trim and door handle is different obviously and a BA trim will NOT fit straight on to an AU door. It can be made to fit but there are several new holes needed to be drilled, also some plastic plug bits for the screws to go into have to be moved The main problem area is around the handle, the metal folds the opposite way I have adapted them by cutting out the BA handle area and bolting it in place of the AU handle area but it is not as simple as it seems. Slight differences in door rubbers, BA has many more clips around the top of the door, where AU's always came off, but they will fit each other Hinges same Handles same I used the BA wiring, easier as everything fits Window parts were upgraded but will fit, power switch inside door is different. Door locks were upgraded but can be swapped by changing an arm or two Another warning is an electric rear window interior will not go onto a wind up door without a few changes either. There is only only 1 type of BA door but the placement of the holes and screw in bung things is different due to the handles and winders. |
22-01-2009, 10:47 PM | #9 | ||
Thanks for that Jastel... thats the info i was looking for!
