24-01-2009, 08:26 PM | #1 | ||
My AU has an annoying problem... When idling it is surging real bad - up to 2000rpm in neutral. In 'D' at the lights its trying to overcome the brakes. Pretty dangerous in carparks etc. You can feel it also on the open road at 110kmh. A real pain in the ****. It isn't idling rough, and still pulls normal throughout the rev range (slowly haha)
Anyway I've heard it could be the idle control valve onto top of the intake manifold (I think). I took it off the other day and gave it a good spray with brake cleaner, still no difference. Is there a way to test if these are buggered (electrical)? Any other ideas/experiences? I've sold the car, and am handing it over in a couple of days, and want to get it sorted before then, otherwise I might have to knock a few hundy off my price haha! Cheers. |
25-01-2009, 12:50 PM | #2 | ||
Hmm, I wish I could help you there, all I can do is put in a shameless bump for you :P
However could it be a fuel system issue? regulator or injectors or some such?
05 BF XR6 ZF 6spd - Stock for now Previously: 98 AU Futura 4.0 - Wildcat Extractors, 200cpsi Stainless Cat, Custom 2.5" Mandrel Bent Exhaust, Tickford Snorkel, Fram 'Airhog' Panel Filter - Daily
79 P6 LTD Silver Monarch - Project |
25-01-2009, 04:05 PM | #3 | ||
Living the Dream
Sounds like a fueling issue, if its doing it both at idle and highway speeds. When was the fuel filter last changed? Might pay to throw a new one on.
25-01-2009, 10:07 PM | #4 | ||
Check for inlet manifold leaks at the font and rear of the manifold; the bolts tend to loosen and burn out the gasket (stick a length rubber of 2- 5 mm rubber tube in your ear and listen for a sucking sound when you put the other end under the inlet manifold at each end.
regards Blue |
