Old 11-08-2006, 06:18 PM   #1
JeffAU1
JeffAU1's Avatar
Default fitting an electric ariel
hey guys
I have a dodgie ariel fitted, and want to fit an electric ariel im looking at buying off eBay.
http://cgi.ebay.com.au/ws/eBayISAPI....MEBI%3AIT&rd=1
Has anyone done this ?
How easy is it and can i do it myself ? (im not that good with cars but wanting to learn)
is it like plug and play ? lol
Jeff
:eclipsee_ MY CAR :eclipsee_
JeffAU1 is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2006, 07:29 PM   #2
bodes-sh
you could also try your local auto parts store, ie repco, supercheap, etc. they sell them to. do you have an aftermarket head unit or the factory one?
Old 11-08-2006, 07:32 PM   #3
JeffAU1
JeffAU1's Avatar
still the factory atm.
Old 11-08-2006, 07:38 PM   #4
bodes-sh
well providing it has a power output for an electric aerial then it should work, basically it has a power, ground and signal wire, so as long as the head unit can output signal then it should be ok. the best thing to do would be to pull off the trim inside the passenger side wheel well where the normal aerial is and see if there is a plug or anything in there to plug into
Old 11-08-2006, 07:46 PM   #5
Stav
Smile
Stav's Avatar
I have bought a few au dedicated aerials and they do not fit in without modification..I hopoe yours does as this can be a pain.
Old 11-08-2006, 08:56 PM   #6
quest
quest's Avatar
Your reception will suffer with electric so its not really worth it
quest is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2006, 09:07 PM   #7
rag top
rag top's Avatar
Isn't the electric aerials on futuras standard?
My 99 futura has one, so I don't think it would be too hard to get it to work. Reception is fantastic!
Old 12-08-2006, 09:10 AM   #8
JeffAU1
JeffAU1's Avatar
well my car had no ariel when i saw it at the dealers, so they fitted a non-standard one
Old 12-08-2006, 09:25 AM   #9
rag top
rag top's Avatar
If you can send me your fax number via PM, I call fax the two pages out of the workshop manual to you on Monday.
It will give you an idea as to what is involved.
Alternatively, you could pick up a manual from an auto parts shop.
Old 12-08-2006, 09:33 AM   #10
quest
quest's Avatar
On any Premium Sound System here Ford will not let you order power aerials
as the parts that slide in each other generate static as it shakes in the wind
Old 12-08-2006, 09:58 AM   #11
JeffAU1
JeffAU1's Avatar
PM Sent.
Old 12-08-2006, 10:25 AM   #12
Burley
CRE.87V
shouldnt there be a 2 pin harness behind the pas kick panel to plug this into??? as well as the aerial extension???....i fitted one to my bro au falcon....just held in by a 10 or 12 mm bolt...easy
i have an auto aerial for sale out of my s1 xr6 if u want to buy it for about 60 bucks....im in newcastle....and im always in the marys to go to tafe
burley
Burley is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2006, 10:33 AM   #13
AU1XLS
AU1XLS's Avatar
burley
Thats how it was for me, only thing you cant control on a series 1 is the height its either up all the way or down. Easy mod
AU1XLS is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2006, 11:02 AM   #14
Whoosha
AU DIE HARD
Whoosha's Avatar
Strange place over there dont think I would pay $1200 extra for premo sound then have to pull me own aerial up and down :
Originally Posted by Riksta
Old 12-08-2006, 11:16 AM   #15
quest
quest's Avatar
Can't pull them up & down at all
Its a fixed mast with no sliding parts
Old 12-08-2006, 11:24 AM   #16
bodes-sh
well being that you're in america i'd say theres a chance that the actual aerial design would be different here, ive never heard of any reception problems with premo sound from aerials causing static
Old 12-08-2006, 11:38 AM   #17
JeffAU1
JeffAU1's Avatar
yeah i was kinda thinking that..
how do i get to the section where the ariel is ??? what do i need to remove and any special tools ima need ?
Old 12-08-2006, 11:42 AM   #18
bodes-sh
afaik just a philips head screwdriver, also it may be easier if you take the passenger side wheel off, to remove the guard cover from inside
Old 12-08-2006, 02:37 PM   #19
Burley
CRE.87V
undo the tree plug in the inner guard...and ull need to bend a tab to get it out...u will see the aerial in there...its held in by one 10 or 12 mm nut..undo this slide it down out from the top of guard....this plastic plug on gaurd may or may not need to be removed for the auto aerial
hope it helps
Old 12-08-2006, 05:14 PM   #20
JeffAU1
JeffAU1's Avatar
hope it helps
sweet thanks man
i'll give it ago - assuming i win this item from ebay
Old 12-08-2006, 06:06 PM   #21
S3SR
S3SR's Avatar
Originally Posted by merkus
sweet thanks man
dont no about that lols ive been waiting for one of these since dawn of time...
My Cars:
2002 Ford Falcon AU S3 SR
2006 BF MKI Falcon XR6
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
2006 Ford Territory TX
2003 Ford Falcon XR8
2009 Territory Turbo Ghia
Current: 2012 Audi A4 B8 2.0T Quattro
S3SR is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2006, 10:29 PM   #22
Burley
CRE.87V
i said in this post.....ive got one id sell ya....make me an offer...im from newcastle
Old 29-01-2009, 10:44 AM   #23
_CRUZ_
Ford Owner
_CRUZ_'s Avatar
The mast in mine has broke yesterday, it's a factory fitted electric aerial, will have to pull it out and replace the mast, put back together on the week end,
After calling ford they sell the mast for $50 and a genuine complete electric aerial for $300, after calling auto barn, they sell a complete aerial to fit au for $119, or a mast for $29.
Will post an update after the jobs done.
_CRUZ_ is offline   Reply With Quote Multi-Quote with this Post
