Old 03-09-2005, 09:37 PM   #1
Jason[98.EL]
Jason[98.EL]'s Avatar
Default running rough in morning
gday all
just wondering what you all might think is my prob
in mornings my ea runs rough and blows a blue smoke for about 10 secs and then when i give it a kick in the guts and clear its throat it runs fine It will do it also every now and then after it has been sitting for the day
any ideas
jason
no longer have a ford but a ford man at heart
R.I.P 98 EL MAY YOU HAVE A GOOD LIFE IN FALCON HEAVEN
[SIGPIC][/SIGPIC]
Jason[98.EL] is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2005, 09:47 PM   #2
klawsterfobik
Bad Music and Litre Bikes
klawsterfobik's Avatar
Blue smoke is oil, if i remember correctly. Does it lose any at all?
Its probably oil leaking past one of your valve stem seals into the combustion chamber of one or more of your cylinders and then getting burnt when you fire it up.
If this is the case you need to replace the valve stem seals in your head.
XY Wagon - NAKED!
Originally Posted by Gammaboy
Anyway. Enough reality, back to the topic.
klawsterfobik is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2005, 09:50 PM   #3
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
Good advice if your sure the smoke is blue.
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2005, 09:50 PM   #4
Jason[98.EL]
head was done about 3k ago
updated to a ed ef head i think not exactly sure
so im dont know
jason
[SIGPIC][/SIGPIC]
Old 03-09-2005, 09:55 PM   #5
ratter
ratter's Avatar
so im dont know
jason
Don't assume that the valve stem seals were replaced, just because the head was replaced, some places cut corners if offereing cheap repairs.
Old 03-09-2005, 10:00 PM   #6
Jason[98.EL]
i know they were as my old man built it and we fit it in the back yard at my olds
so i dont know what the prob is
jason
[SIGPIC][/SIGPIC]
Old 03-09-2005, 10:09 PM   #7
ratter
ratter's Avatar
jason
Have the valve guides been replaced?
If they are worn it could cause a valve stem seal not to seal correctly
Old 03-09-2005, 10:11 PM   #8
Jason[98.EL]
yup all done
[SIGPIC][/SIGPIC]
Old 03-09-2005, 10:16 PM   #9
ratter
ratter's Avatar
If it's blue it points to the valve stem seals leaking after sitting for a few hours, it either has a damaged seal from fitment or the smoke may not be blue, otherwise I'm out of ideas.
if it's blue, it has to be getting oil into the combustion chanber from somewhere, the only place normally when left sitting is stem seals.
