Old 05-09-2005, 06:26 AM   #1
Nik
Default streetfighter vs dev 5 cam
could tell us how much more power you would get changing from a streetfighter cam to a dev 5?
do you do a larger cam than a dev 5 for an au?
also do you guys do billet cams ?
thanks jake
Old 06-09-2005, 04:52 PM   #2
Stav
Smile
Stav's Avatar
Jake another forum member here EDI6 has swapped from a dev 4 to dev 5 and so far he got a dev 4 14.2 1/4 and with the dev 5 so far a 14.1
seeya
stav
Old 07-09-2005, 03:47 PM   #3
V8 Ghia
Formally ED I6
V8 Ghia's Avatar
seeya
stav
Unfortunately the 14.21 with the streetfighter cam was done with street 225's and 3.45 lsd.
Whereas the 14.17 was done with a dev5 cam, 3.9 lsd and M/T slicks
So they can't really be compared.
I'm starting to think when I had the cam changed I had a bad tank of fuel and the same tank was used at the drag strip as the car had less power in 4th gear (165rwkw with the streetfighter cam and 160rwkw with the dev5 cam).
If fuel wasn't so expensive at the moment I would take it down the 1/4 again.
Daily driver
98' AU 349ci Fairmont Ghia on LPG
Other
93' ED 5spd 4.0L NA Fairmont
13.75 @ 101mph
V8 Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2005, 08:15 PM   #4
Nik
ed i6 how much difference did going from the 3.45 to 3.9 make to your acceleration?
Old 08-09-2005, 12:07 AM   #5
QUIKXR6
Kurucu Performance
QUIKXR6's Avatar
Hey guys....long live the dev 5...i have the dev 5 cam in my car..i always seem to be pulling more power out of it....i managed a 14.0902 down the 1/4 mile with my 225/65/15 street radials at heathcote test n tune on the 27th of last month... i beleive i can bring that down into the 13's....with a proper tune up....new sparkies and a bit more tricks...here n der...i just love hearing my baby dev 5 cam scream its guttts off to give me more power....lol...i'd say the dev 5 kicks asss.... over any other cam...
174rwkW N/A I6 Kurucu Performance Enhanced...
Heathcote Test & Tune 28/08/05 - 14.0902 @ 97.61mph
Now With EL XR6 Engine & ECU & 3.7 Gears
Www.KurucuPerformance.Vze.Com
QUIKXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2005, 04:24 PM   #6
V8 Ghia
Formally ED I6
V8 Ghia's Avatar
It's a better ratio for the drag strip as I cross the line at around 5000rpm in 4th as opposed to 4000rpm. IMO if its only for the street its probably a bit excessive.
Daily driver
Other
13.75 @ 101mph
Old 08-09-2005, 05:34 PM   #7
Nik
thanks mate .i was thinking diff gears instead of a cam upgrade but its still gunna be a daily driver for nik.
might hang onto my cash for a bit and see how the new head pans out.
