09-11-2005, 11:50 AM | #1 | ||
XR6UTE
Just replaced the head gasket recently and upon the first drive found that the car has a huge flat spot while taking off. when you put your foot down it seems to gargle for a few seconds and then get its **** into gear.
i had a look under the bonnet and found a blue clip that comes out near one of the coolant hoses. its almost the same as one of the clips that goes onto the injectors. its covered in dust and i dont remember taking it off.??? Does anyone know if this had anythin to do with the flat spot? Or know whats goin on??? Cheers Willsy |
09-11-2005, 12:14 PM | #2 | ||
i would say the fuel/air mixtures arnt right,when you bot it its flauding, dose it happen when you accelerate slowly??
09-11-2005, 12:20 PM | #3 | ||
XR6UTE
yeh it still happens when exalurating slowly
09-11-2005, 12:22 PM | #4 | ||
yep those mixtures are way out :(
09-11-2005, 12:32 PM | #5 | ||
XR6UTE
so what can i do to fux the problem :
09-11-2005, 12:54 PM | #6 | |||
meow
"I would say the fuel/air mixtures (AFR's) are not correct. When you boot it floods (flauds) Does it happen when you accelerate slowly? My guess would be a rich AFR. When you give it some it may take the ECU a second to work out what's going on before responding. Your injectors may also be a bit dirty. |
09-11-2005, 12:59 PM | #7 | ||
XR6UTE
Well how can i make the AFR's right?
09-11-2005, 01:07 PM | #8 | ||
Former E-Series Member
Change fuel filter? Injector cleaner and 98 Octane fuel? It's good to start with the simple things.
10-11-2005, 08:07 PM | #9 | ||
XR6UTE
Hey i just checked the previous head gasket i pulled out and found that it was alot thicker than the one i replaced it with... Does the gasket come in different sizes??? And could this be my problem?? :yeees:
