Old 07-12-2005, 07:16 PM   #1
HSVETAR
Bring on the lion...
HSVETAR's Avatar
Default solinoid shift kit
i have been told that i can get a solinoid fitted to my air lines in my auto which is compared to a stage 2 shift kit. has anyone else have this in there car and if so what sort of shift do you get. i dont want it to be too rough as my car is more of a cruser than a speed machine.
El falcon, 4.0, XR6 camshaft, pacemaker extractors, 2.5 inch exhaust with tri flow sports muffler, AU TE50 intake, with K&N panel filter, Advanti racing Stalker 17" rims, Sitting on Ultra Low King Springs, 'Gabriel' Ultras Lowered struts, NOW MANUAL, 3.45 LSD
9.694 @ 75.38 MPH at Mildura Drag Strip 1/8 Mile
XC Falcon project car underway......
HSVETAR is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2005, 09:06 PM   #2
EF_Frmnt
EF_Frmnt's Avatar
You cant get an old stuffed solenoid out of a borg warner 3 speed auto and put that in your 4 speed an that will make it shift hard.. chirp second.
EF_Frmnt is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2005, 02:20 AM   #3
PetesEBII
Formerly PetesEB
if you are talkin about the one they sell on ebay.....its poo.
Hammered the box quick.
:gren: Weapon of choice. :gren:
EB II, T5, Custom extractors, 2.5'' all the way thru, hardly legal tint, EL XR rims, on its balls, cold air intake + stainless heat shield. Custom boot garnish.
PetesEBII is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2005, 08:41 AM   #4
HSVETAR
HSVETAR's Avatar
na, i was talken to a guy and his dad works at sunrasia auto, and he said that they have fitted a few and they havnt had any complaints yet. $300 tho so i want to b sure before i think of geting it put.
Old 08-12-2005, 08:42 AM   #5
LTDHO
The one and only
LTDHO's Avatar
HSVETR - There are two ways.
The easier of the two is the electronic shift kit. It can be switched on and off. It's quicker to do.
Other wise you can swap your s5 soliniod with one out of a Commodore, this wil firm shift.
BTW, where ya located?
1992 DC LTDHO 360rwkw built by me
Tuned by CVE Performance
Going of the rails on a crazy train
Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
LTDHO is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2005, 08:53 AM   #6
HSVETAR
HSVETAR's Avatar
Im in Mildura.
The electronic shift kit- does it just increase the air pressure?
Old 08-12-2005, 09:06 AM   #7
4.9 EF Futura
Official AFF conservative
4.9 EF Futura's Avatar
Originally Posted by HSVETAR
Im in Mildura.
Fluid line pressure, yes.
Another alternative is to fit an AU variable pressure solenoid (S5) which can be adjusted.
A cup half empty... but full of euphoria.
4.9 EF Futura is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2005, 09:20 AM   #8
EA2BA
PM me if you want
EA2BA's Avatar
All S5 solenoids can be adjusted, thats how they work, it's just that the AU S5 was the first used that way i.e. adaptive shift, but at the end of the day, the AU S5 is cheaper when replacing your S5.
Owner of first ever car to retrofit BA SSS - the EA2BA
Send me a PM if you want to know anything
2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
EA2BA is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2005, 09:28 AM   #9
4.9 EF Futura
I was referring to the manual adjustment which can be made....
Old 08-12-2005, 09:33 AM   #10
EA2BA
PM me if you want
EA2BA's Avatar
Oh ok fair enough then.
Old 08-12-2005, 09:50 AM   #11
HSVETAR
HSVETAR's Avatar
how are they manually adjusted? and how much to these AU s5 solinoids, also how do u put them on?
Old 08-12-2005, 09:53 AM   #12
4.9 EF Futura
The adjustment is physically made to the end of the solenoid IIRC - like an adjustment screw. IIRC they are not cheap.
However the end result is basically the same as an electronic shift kit - increased line pressure within the transmission. PM me if you would like to know where to find instructions on building the electronic shift kits (I dont want to be plugging other forums here on AFF, lol).
It shouldnt cost you more than $10 to build and to be honest they're quite fun to make/install.
Old 08-12-2005, 09:57 AM   #13
EA2BA
PM me if you want
EA2BA's Avatar
The electronic shift kit is better anyways, as it can be turned off, if you manually adjust the AU S5 for harsh, then harsh it is 24/7.
Old 08-12-2005, 09:58 AM   #14
4.9 EF Futura
Very well put!
Old 08-12-2005, 10:17 AM   #15
LTDHO
The one and only
LTDHO's Avatar
Very well put!
Which is dangerous in the wet.
Also when you have family in the car they may prefer softer driving!
Old 08-12-2005, 10:38 AM   #16
HSVETAR
HSVETAR's Avatar
how is the electronic on wired in?
Old 08-12-2005, 10:42 AM   #17
4.9 EF Futura
Basically a couple of resistors wired into the gearbox wiring. As mentioned, send me a PM and i'll direct you to the instructions
