Old 07-12-2005, 12:13 PM   #1
eav8
eav8's Avatar
Default can a windsor starter be mounted to clevo
As in title. Can I bolt a windsor v8 starte motor to a standard 2 bolt clevo bellhousing. I realise that the windsors have a three bolt arrangement but I was thinking that if 2 out of the three lined up and the starter gear meshed properly then maybe I could utilise it?
If not does any one know where I could chase up a clevo starter motor that when changed to passenger side will have the solenoid facing upwards instead of down?
project #1: Ea series1 Spac conversion to straight gas; 351Cleveland; T5; EB dash; sunroof and more as I get to them. :evilsasmo
Fully road legal and cruising in QLD!!
Happy dealings with; PROTD, !gn!t!on, Big_waity,Phongus
eav8 is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2005, 12:32 PM   #2
RavenLS1
maybe a Q for the general tech boys, you think.
405rwhp LS1, FG XR6T Ute manual, VE series 2 Omega LPG.
RavenLS1 is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2005, 12:44 PM   #3
darnoldrs
Great question. I need to know the same thing. They are avalible from "Castle main rod shop" but at $400.+ for a geared hi-torque starter.
Early clevland and windsor starters are the same(to the best of my knowlage) but the 5.0 winsor is not compatible with a clevo for sure. David
darnoldrs is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2005, 08:27 PM   #4
INJECTED_250
Custom user title
INJECTED_250's Avatar
mate u can use a 4.0 6 cyl stater on a clevo a bit of grinding is required so the ring gear misses the starter body. but once set up its quite a good gear reduction starter
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2005, 09:47 PM   #5
eav8
eav8's Avatar
is 3.9 ea starter the same as the 4.0 starter? I ask this I have a spare one laying around somewhere and hadn't thought to check it out.
Old 07-12-2005, 09:56 PM   #6
bprint xr8
more posting less lurking
bprint xr8's Avatar
The 3.9 starter is not the same as the 4.0 starter as I believe it is not gear reduction, but still has the same bolt pattern. Certainly worth trying if you have one sitting around
BA XR8 Devil R - SY Territory TX AWD - MQ Nissan Patrol 302c - GQ Nissan Patrol
bprint xr8 is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2005, 09:56 PM   #7
Damo
yep they're the same physicaly.
Damo is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2005, 10:06 PM   #8
INJECTED_250
Custom user title
NO there not the EA starter is massive compaired to the 4.0 starter...
Old 08-12-2005, 09:34 AM   #9
eav8
eav8's Avatar
no worries I'll hunt up a 4.0 starter...Shouldn't be too hard or expensive to track one down......hint hint ??
Old 08-12-2005, 10:39 AM   #10
darnoldrs
let us know how you go and if it all fits up ok. David
Old 08-12-2005, 12:15 PM   #11
eav8
eav8's Avatar
will let all know how it goes as I progress. Will post updates in my ea into cleveland thread....
Old 08-12-2005, 08:08 PM   #12
INJECTED_250
Custom user title
you need to mod them a little.. and also watch the steering box arm as it can be close to the starter depending weather its p/s or manual box
Old 08-12-2005, 08:23 PM   #13
eav8
eav8's Avatar
isn't the 4 litre starter usually mounted on the passenger side? this then means orientation of the solenoid should be upward hopefully.
Old 08-12-2005, 09:37 PM   #14
Damo
i'm positive the 3.9 starter is the same, i have a 3.9 and 4.0 and have changed the clutch in both recently and was positive they were the same. I guess my eyes decieved me.
Old 08-12-2005, 09:43 PM   #15
INJECTED_250
Custom user title
ones a gear reduction one. and ones a big old fat one like an XF starter
