19-12-2005, 05:20 PM | #1 | ||
Formerly eawags
Any ideas why this would happen guys?
Temp is showing a little above half but the overflow is rattling its head off boiling. Thanks |
19-12-2005, 05:32 PM | #2 | ||
Last warning
has it got only water in it? or proper coolant mixture?
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
19-12-2005, 05:34 PM | #3 | ||
windsor user
are you sure its boiling or is it just bubbling. it hasnt got a blown headgasket by any chance?
19-12-2005, 08:33 PM | #4 | ||
Formerly eawags
Found the problem. The belt has snapped from the water pump and alternator.
Any handy hints on getting a new one on? Looks like the powersteer one will have to come off first. |
19-12-2005, 08:39 PM | #5 | ||
Undergraduate EB Operator
i got a new one from ford but you can get one wherever you like, you will need a 13mm ring spanner and a 23 or 24 ml open end spanner to get the power steer off then the same thing for the alternator i think.
on the power steer the 13 ml is the tensioner and on the altenator it's the locker, dont get them mixed up or you will strip the teeth.
Simon ----------------------- 04 BA Xr6 ... now with carpark dints ----------------------- |
19-12-2005, 09:13 PM | #6 | ||
the motors been cooked, that's why its boiling in the overflow.
The gauge was reading normally, because it's gone past the point of reading hot and you didn't see it, the gauge sender was then reading steam rather than water and that will not give a correct temp reading. if your lucky a new belt will be all thats needed to fix it, if your unlucky you'll need a new head gasket
19-12-2005, 09:58 PM | #7 | ||
did your alternator charge light not come on in the dash??? That'd be the first warning something wasn't right
19-12-2005, 11:21 PM | #8 | ||
Formerly eawags
Wife was driving guys, she did the same thing to our last car a v6's camry.
Yes the battery light was on which is way i checked the alternator. She still goes alright RATTER....fingers crossed. |
20-12-2005, 10:10 AM | #9 | ||
Former E-Series Member
I once had boiling/bubbling coolant in the Laser on hot days. Turns out the coolant was some absolute brown sludge that was god knows how many years old. I changed it and it's been fine ever since.
20-12-2005, 01:12 PM | #10 | |||
20-12-2005, 01:17 PM | #11 | |||
Haltech 302w XW
lol dad's boss's wife did the same thing only in a BMW M5...opps that was a rather expensive mistake.
1969 XW Fairmont-1999 explorer 5.0- comp cam XE270HR, 9.8:1comp, Ported Gt40p, Ford Racing oil Cooler, EL V8 radiator & thermo's, Fuel/intake -XR6T injectors, 255 LPH intank pump, 4" intake, HaltechE11v2 Exhaust-custom Tri-Y headers, Twin 2.5" HiFlo Cats, duel 2.5" exh Driveline-close ratio 4spd, 9" LSD, 300mm AU XR8 fr, XC rear, ZH Fairlane Mas/Cyl & Booster Project car: http://www.fordforums.com.au/showthread.php?t=21641 |
20-12-2005, 01:34 PM | #12 | ||
Formerly eawags
Got the belt on after battling the oil sludge (to find the bolts) and all seems good!
