Old 30-12-2005, 02:21 PM   #1
NEG
Diabolus
NEG's Avatar
Default Trouble starting
Hi guys just wondering if someone could help me out with my EF, I've been having some problems starting it. Turn the key to start and nothing happens, I can hear the fuel pump working and all the lights on the dash seem normal. lights dont dim if i try starting it with them on, the starter motor dosnt even seem to do anything iv checked all the wireing connections. The strange part is after trying to start it for 10 to 15 minutes it will start no worries. has anyone ever had this happen to them befor i start replacing things?
thx
also its a manual.
NEG is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2005, 05:05 PM   #2
HSVETAR
Bring on the lion...
HSVETAR's Avatar
Same with one of my mates EB, we havnt figured out what is causing it either, Manual also, any help would be good.
El falcon, 4.0, XR6 camshaft, pacemaker extractors, 2.5 inch exhaust with tri flow sports muffler, AU TE50 intake, with K&N panel filter, Advanti racing Stalker 17" rims, Sitting on Ultra Low King Springs, 'Gabriel' Ultras Lowered struts, NOW MANUAL, 3.45 LSD
9.694 @ 75.38 MPH at Mildura Drag Strip 1/8 Mile
XC Falcon project car underway......
HSVETAR is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2005, 05:08 PM   #3
clontarf_x
neutral safety switch? dead ecu? smartsheild dead? i wouldnt have a clue im just listing things you might wanna look at
also, starter motor seized? bash it with a large blunt object a couple of times and see if that works, happened to my xf
clontarf_x is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2005, 05:26 PM   #4
NEG
Diabolus
NEG's Avatar
ok i tried a few things and rolling the car back or forward slightly with it in gear to turn the motor a little. It started after i did that. Is it possible that the cam angle sensor isnt workin properly?
Old 30-12-2005, 05:36 PM   #5
snypereb
[EBGLT]
snypereb's Avatar
I think i have read about this problem before check through diff threads maybe they will be able to help you out!
[EBGLT]
Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/
snypereb is offline   Reply With Quote Multi-Quote with this Post
