Old 01-01-2006, 04:32 PM   #1
Damo
Default Differance between 3.9 & 4.0 block ?
Hey all,
Just a quick question. I picked up a motor for my EB the other day it's a 3.9, anyways on the front of the motor it has 87DA-6059-AA. I had a look at the motor in my EB (series 2, pre smart lock) and it also has 87DA-6059-AA on the front of the block, the head is a 91AA. I found this a bit strange as it is supposedly a 4.0.:
Did they have the same code for the 3.9 and 4.0 blocks ? Or has my car been stooged from the factory. : :
Damo is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2006, 04:43 PM   #2
stockstandard
Id say since both 3.9's and 4.0's come from the same casting (I believe) you probably havnt been stooged. A 4.0 is just a 3.9 that has been slightly bored out.
Originally Posted by casper
Yeah, the car is ugly, I can live with that.
stockstandard is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2006, 06:24 PM   #3
5L
[ 5L ]
5L's Avatar
im not sure on this but someone told me that is was just the heads that were different but im not sure on this for sure
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline)
www.ignitionimages.com
5L is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2006, 06:36 PM   #4
Damo
someone with an EB2 wanna have a look at the front of the block and tell me what numbers are printed on it ? it's just under the idler pulley.
Old 01-01-2006, 06:38 PM   #5
EBFalcs
mine says 91AA
EBFalcs is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2006, 07:14 PM   #6
QUIKXR6
Kurucu Performance
QUIKXR6's Avatar
maybe the engines headgasket has been changed and at the same time the head may have been replaced...
174rwkW N/A I6 Kurucu Performance Enhanced...
Heathcote Test & Tune 28/08/05 - 14.0902 @ 97.61mph
Now With EL XR6 Engine & ECU & 3.7 Gears
Www.KurucuPerformance.Vze.Com
QUIKXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2006, 07:22 PM   #7
Damo
but's it's suppossed to be a 4.0 It doesn't really faze me, the motor is stuffed anyways, but i just wanna know if the EB 4.0 motors were 87DA-6059-AA. Maybe cause mine is an Early EB2 they used the same numbers.
EBFalcs - I think you were lookin at the head, mine is 91 AA too, i'm interetes ion the numbers on the fron of the block above the Balancer.
Old 01-01-2006, 07:27 PM   #8
gthofan
Gunna girlie-man
gthofan's Avatar
the two engines also have different power.
*3.9L multi-point 6 cyl
Bore and stroke: 93 x 99 mm
Power: 139kW at 4250rpm
Torque: 338Nm at 3500rpm
Overhead camshaft, 2 valves per cylinder
Fuel system: EEC IV fuel injection
Compression ratio: 8.8:1
4.0L 6 cyl (Series II)
Bore and stroke: 92 x 99 mm
Power: 148kW at 4500rpm
Torque: 348Nm at 3750rpm
sorry bout that, just had to confuse the situation!!!
WADE CAMS-- UNLEASH THE POWER!!
<INSERT WITTY SIGNATURE HERE>
Daily- 05' BA futura... work done.
Cruiser- 85' VK berlina... more work done
gthofan is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2006, 07:35 PM   #9
Matt_971
Regular Bum
gtho fan how can the 4ltr have a smaller bore than the 3.9?
I thought the differnce was just the bore???
THanks
Matt
Matt_971 is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2006, 07:43 PM   #10
gthofan
Gunna girlie-man
gthofan's Avatar
i got the info off this website!!!
http://www.geocities.com/falconfacts.../ebfalcon.html
check it out. every falcon made, sweet website, shows all stats
Old 01-01-2006, 08:30 PM   #11
INJECTED_250
Custom user title
INJECTED_250's Avatar
i thikn u will find that that part no is just the one of the timing cover mabie???.. or is that the actualy number CAST into the block(steel)
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2006, 08:32 PM   #12
Damo
yeah it's on the timing cover lol. So it's just a the part No for the timing case, that would make sence. Thanks injected!
Old 01-01-2006, 09:58 PM   #13
INJECTED_250
Custom user title
THe 3.9 blocks are slighly narrowier where the oil gallery is on the side, its a visual differnece,
Old 01-01-2006, 10:19 PM   #14
John_LS1
Posts: n/a
EA and EB engines shared the same timing cover 87DA as mentioned. only ED got the later 91 DA timing cover with EF style top gasket ;)
Old 02-01-2006, 12:57 PM   #15
needfordspeed
The block's part number is locatad on the bottom of the exhaust side, just above where the sump bolts up.
Good to see you got a new motor. How much was it? Is it stock or is there some work done to it or something?
Sundeep
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH
needfordspeed is offline   Reply With Quote Multi-Quote with this Post
