31-01-2005, 03:14 PM | #1 | ||
Free Energy Is Out There
Greetings all, have a couple of queries, has anyone dealt with Gimmecarparts.com.au? Are they OK to deal with? and I've found 3 ACL Monotorque head gasket sets which all seem to fit my car, but which on is the correct set to use? From compliance plate in engine bay Model 18364, Engine H and Built June 1994. Parts from gimmecarparts.com.au as follows:
Part No. HS520MT Ford 4.0l EB-ED Inline 6 SOHC 2v $67.52 " " . HS522MT " " " " " $68.74 " " . HS522MTG " " " " " $71.41 If anyone can help I would sure appreciate it. I've been told that the ACL Monotorque are the gaskets to use, does everyone agree?? Thanks Paul. |
31-01-2005, 07:18 PM | #2 | ||
Two > One
The Monotorque gaskets are good, but why not use the AU steel gasket for a few extra points of compression whilst the heads off.
1978 LTD - 408ci - 11.5@120.6mph - 2004 S4 - 4.2 - M6 - quattro - |
31-01-2005, 09:14 PM | #3 | ||
Hi, if this a better option OK. Does anyone know the part number? Or can any AU steel gasket be used? Thanks.
31-01-2005, 09:15 PM | #4 | ||
Last warning
just goto ford and ask for an AU II Headgasket.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
31-01-2005, 09:56 PM | #5 | ||
Number 5 is alive!
Use an AU gasket.
Worth the few extra $$$$.
Kerry Tickford wings are for Tickford cars! "Experimental Racer" #6 1994 Gunmetal XG XR6 1997-1999 [B][COLOR=Red] 1994 Le Mans Red ED 2008 MA XR5 Mondeo 2015 VOLVO V60 T6 R-DESIGN-POLESTAR Enhanced |
31-01-2005, 10:12 PM | #6 | ||
Low and Loud
Monotorque Gaskets are what ive been recommended to by many Engine reconditioners. Those Cheapo Supercheap Auto ones are terrible.
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon : |
31-01-2005, 10:16 PM | #7 | ||
I build your wish list...
$68 for the AU II head gasket from ford
$25.70 for head bolts from bursons its the best $100 you will spend on your motor
If it weren’t for physics and the law enforcement, I’d be unstoppable.
01-02-2005, 06:03 AM | #8 | ||
Thanks heaps for the feedback, seems like I had better go with the AU steel gasket.
01-02-2005, 06:29 AM | #9 | ||
By the way, will I have to replace all the other gaskets aswell? Buy a gasket set? What gasket goo is the best.Q's, Q's and more Q's. Thank God for you people on this forum!!!!
01-02-2005, 08:30 AM | #10 | ||
Last warning
damn.... i paid like $70 for headbolts from ford :o
i know not to do that again... depends on the condition of the gasket, intake manifold gasket is usually ok, exhaust gasket depends (i had to replace mine), i'd replace thermostat housing gasket anyway. rocker cover depends if its leaking or not. i've got selly's blue gasket stuff... and the bronze stuff for the exhaust side
01-02-2005, 09:20 AM | #11 | |||
RIP...
Rick.
. Oval Everywhere... |
01-02-2005, 11:07 AM | #12 | ||
On that note, though, the torque sequence is different if you are using an AU head gasket + bolts, isn't it?
I know EA-ED is 40 Nm + 90 degrees... what is AU? |
01-02-2005, 11:12 AM | #13 | ||
Last warning
30nm + 120 degrees
03-02-2005, 10:54 AM | #14 | ||
E-Series Owners Club
The AU Gasket is the best option IMO.
But as for those three part numbers - ACL make three different thickness gaskets: Standard, thinner (to raise compression), and thicker (to lower compression). Not sure which part number realates to which gasket though... |
03-02-2005, 06:56 PM | #15 | ||
02/90 EA II Fairmont
autobarn should be able to look up the part numbers... go find them out there and if you can get them cheaper elsewhere, do so
211RWKW EA |
