Old 30-01-2014, 08:02 AM   #1
Dave 64
Default General Query
Hi All,
Am in Central Vic, trying to source both a bit of info as well as hard to get bits and pieces for 1968 F350 trady's wagon.
Am currently in the midst of a project where I am either trying to locate original parts, or alternatively, adapt parts from another Ford product.
Going through the clutch and brake rebuild at the moment, found that the nylon bushes in the clutch/brake pedal pivot up under the dash within the pedestal, are simply flogged out. Also the clutch return spring rests on two small nylon saddles , probably to stop them rattling. Tried a few local places, all I seem to get is blank looks.
A mate suggested that it's quite possible that another Ford product may have used the same set up. Probably going to need quite a few fiddly bits like these in the near future. Can anyone direct me to either a Ford F truck parts supplier, or a hard-to-get general Ford replacement dealer? Would be appreciated, not real brilliant on doing searches on the internet, but if I get a heads up, should be able to direct my queries.
Thanks for any help,
Cheers, Dave 64
Dave 64 is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2014, 01:49 PM   #2
Boza
Boza's Avatar
Default Re: General Query
Hey dave try eagle auto parts in dandenong they specialize in parts for old yank stuff also theres a bloke in thomastown who specializes in early f trucks I beleive the bushes in the pedal box are same as our falcon's just pull the bushes ut and go to a local parts shop and measure them up that's what we used to do at auto brake service I know transit vans had same size bushings as some falc's or corty's so try this method
92 South Gippsland HWY
Dandenong 3175
Phone: 03 8710 3000
Mon - Fri 8:30am - 5.30pm
Sat 9am - 1pm
also try this site it's for f truck parts in australia
http://www.ftrucksaustralia.com/
Boza is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2014, 02:51 PM   #3
mik
mik's Avatar
If you can't get the bushes some bearing places sell nylon in stick and you could make some yourself.
Old 30-01-2014, 08:05 PM   #4
Dave 64
Thanks, Guys.
Local Ford dealer went out of his way on his own time to locate one half a set of nylon bushes. Way too thin to try and machine nylon, but got hold of two bronze bushes and will machine the eye of the pedal out to suit, then ream it.
Don't know about the anti-rattle saddles on the end of the clutch pedal return spring, again may have to try and adapt something else.
Dave64
Old 31-01-2014, 07:31 AM   #5
nuthin' fancy
Lyminge, Shepway, Kent
nuthin' fancy's Avatar
There is F series wrecker near Geelong. http://www.westcoastf100.com.au/
Mel Brooks sums it up best;
"Comedy is when you fall into an open sewer and die, tragedy is when I get a paper cut"
nuthin' fancy is offline   Reply With Quote Multi-Quote with this Post
