Old 17-11-2016, 12:52 PM   #1
car10002
Default Ba ecu
Hi
Will probably go au engine but wondered anyway
How do you wire up the ba ecu so engine runs on it's own?
What wires in the ba ecu harness do you need to run the engine on it's own?
Has anyone got wiring diagrams they can help with?
How do you connect the ba engine ecu harness to a ef or el wiring harness so the ba ecu runs engine and the ef/el ecu runs the dash and gearbox and rest
Can you use a au throttle body with the cable
Thanks
car10002 is offline   Reply With Quote Multi-Quote with this Post
