Old 26-09-2017, 02:36 PM   #1
dowdsy
Default New distributor for 351 windsor that will fit under a shaker
Anyone got any ideas? cant seem to find anything that will fit they are all too tall.
dowdsy is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2017, 04:11 PM   #2
GTLEGEND
Default Re: New distributor for 351 windsor that will fit under a shaker
What's wrong with the original?
Old 26-09-2017, 06:05 PM   #3
dowdsy
Pertonix has failed and the vacuum advance is not holding, its pretty much just worn out heaps of play on the base plate. Figured i would just buy a new one but nothing will fit except for ice setup $1300 though pretty expensive.
Old 26-09-2017, 06:42 PM   #4
XW 393
"WHEEZER" POWERED
XW 393's Avatar
Having had an ICE setup, the money is worth it. Great products and service.
FG MK2 XR6 DAILY - BLOWN VE SSV Z SERIES TAILY
XW 393 is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2017, 06:42 PM   #5
GTLEGEND
I will see if I can find out for you have a friend that works a large speed shop and get back to you. You can have yours rebuilt by someone like below also?
https://performanceignition.com.au/contact
http://www.mako.com.au/ibm_custom/se...ervice_142.htm
Old 27-09-2017, 10:10 PM   #6
GTLEGEND
My reliable source advised that the MSD 8578 red cap or MSD 85783 all black will fit under the shaker of a 351 Windsor. I cannot confirm, but would check the advise. Dimensions can be found on the link below which you could use to check on vehicle.
https://www.msdperformance.com/produ...ord/parts/8578
Hope this helps!!
Old 28-09-2017, 11:14 AM   #7
dowdsy
Hope this helps!!
Thanks, GTLEGEND, after more investigating with my car it looks like my external voltage reg has died, Chinese copy not very old and second one to fail.
Old 29-09-2017, 02:46 PM   #8
HIPO
Al
HIPO's Avatar
Thanks for the links, i'll suss out Mako for my K-codes dist. as it has a fair amount of play in it!
HIPO is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2017, 05:52 PM   #9
The MSD 8578 will at least need an MSD 6. it is also compatible with a 7 or 8.
Old 29-09-2017, 07:06 PM   #10
GTLEGEND
Yes I forgot to mention it also needs the ignition box..thanks..
Old 29-09-2017, 07:12 PM   #11
dowdsy
Spoke to performance ignition and they were very helpful looks like rebuilding old one with electronic ignition is the go.
