Old 19-03-2006, 03:47 AM   #1
FPVWEPN
Team Urinal Cake Racing
FPVWEPN's Avatar
Default Smshxprs
Hey guys had a bit of a bingle and whacked the kerb pretty hard at about 40 kays and damaged front bar aswell.
Took off to drive home and noticed that the front right wheel is about 5cm back furthur than where it should be and the alignemnt is like 20 degrees out. Also because the tyre is pushed back, lock to lock is not achievable. The left side is in the normal position however. What am i looking at here new steering rack? swaybar??? whats bent thats causing it to sit so far back???
Thanks George
FPVWEPN is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2006, 03:54 AM   #2
theboss290
FPV GT
theboss290's Avatar
Kerb @ 40k's = ouch! will probably = $$$$$$ = ouch! = :
theboss290 is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2006, 03:56 AM   #3
5L
[ 5L ]
5L's Avatar
i had one like that was wet and drifting and the front wheels slide into a gutter at bout 40 kays and smashed my front mag in 2 and popped the steering rack tie rod ends into the rack. yours sounds like lower control arm is bent
(this was in my last eb which was a slow auto 3.9 series 1)
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline)
www.ignitionimages.com
5L is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2006, 07:44 AM   #4
TWiZTiD
TWiZTiD EA
TWiZTiD's Avatar
might be the stub axle or lower control arm i would say
10/89 EA 11 Spac5 Speed, Mpfi, EL XR6 Cam, EF/EL Thermo Fans, EL BBM Intake, Sports Exhurst, ED Bonnet, ED XR6 Boot, Boot Lip, Garnish and Lights, ED Electric Mirrors, Trip Computer, Clear Indicators, EB XR6 Steering Wheel, King Superlows, Monroe GT Shocks and EL GT copy Rims.
15.3 @ 90 mph
TWiZTiD is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2006, 09:26 AM   #5
Poetic Justice
NOT A TOYOTA :/
Poetic Justice's Avatar
I did the same thing in my lancer, understeered coming into a roundabout in the wet one night and collected the gutter.
Broken control arm and bushes? Wheel was pushed back and scrubbing the guard. Was a nightmare to get home...
06 LandbargeCruiser Sahara
Managed to remain in the v8 fraternity
Poetic Justice is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2006, 10:03 AM   #6
NZ
NZ's Avatar
I've seen the same thing in an EA. Needed a lower control arm, radius rod, new rack and i think a new shock but unsure on that.
EF Falcon Sedan 5.0 auto with IRS
"the man that crashs AFF"
NZ is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2006, 10:31 AM   #7
Polyal
The 'Stihl' Man
Polyal's Avatar
LOL...who could of that been karl?
:baby bott
  • 2017 Toyota Prado (work hack)
  • 2017 Mitsubishi Pajero Sport
  • 2003 CL7 Honda Accord Euro R (JDM) - K20A 6MT
  • 1999 Lexus IS200 - 1G-FE Turbo 6MT
  • 1973 ZF Ford Fairlane
Polyal is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2006, 10:49 AM   #8
NZ
NZ's Avatar
You needed a new k frame as well didnt you?
<3
Old 19-03-2006, 11:41 AM   #9
FPVWEPN
FPVWEPN's Avatar
well i hope it aint the k-frame
as for steering rack ive got one out of an ed there a direct swap with an ef yes????
Old 19-03-2006, 12:56 PM   #10
John_LS1
Posts: n/a
nope EF steering racks are different to ED
Old 19-03-2006, 01:06 PM   #11
efgiar
rofl copter
efgiar's Avatar
john_xr6, how different? my car seems to have a really crap turning circle, the steering rack was swapped just before i got it. is it possible to put an ed one in and would it effect the turning circle?
GQ patrol.
thats all
Old 19-03-2006, 01:06 PM   #12
EL_futura
Id say you could be up for a bit of dosh mate... Steering rack i'd say will be stuffed, well at least the tie rod. Looking about $300 + fitting (fully reco).
I'd be suprised if you did bend the sway bar though... I've seen some cars that have hit kerbs pretty hard, and sway bars are ok.
I'd also say your frame would be bent, and your radius rod is bent aswell. Might have damaged your lower control arm too...
Get it in somewhere to get it checked out. Pedders does a $14 28 point safety check, which will give you a good idea of whats wrong.
Matt
EL_futura is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2006, 02:11 PM   #13
John_LS1
Posts: n/a
im pretty sure the turning cirlce is the same, e-series have crap turning circles. the main difference is the way the intermediate shaft bolts up to the steering rack.
Old 19-03-2006, 02:14 PM   #14
dansedgli
dansedgli's Avatar
Thats a bugger. I saw your car on chapel friday night. It was looking pretty good!
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2006, 04:41 PM   #15
Polyal
The 'Stihl' Man
Polyal's Avatar
Matt
Yeap get it checked.
when I had my "off" pedders made me sign a paper that said I shouldn't be driving it...so I did and drove home, who do they think they are!
But yeah, its worth the $14.
Karl...k frame was a it bent but I dont remember changing it.
Old 19-03-2006, 04:48 PM   #16
efgiar
rofl copter
efgiar's Avatar
mine seems to be worse then my dads el and my ИИИ ed... as they can get onto the front lawn in 1 turn, i have to reverse and take another go. same size wheels and lowage on all cars.
GQ patrol.
thats all
Old 19-03-2006, 06:55 PM   #17
FPVWEPN
FPVWEPN's Avatar
ok guys jacked up the car and took both front wheels off for inspection:
- Radius rod arm bent
- Lower control arm bent
- stabiliser bar mounts bent
- k-frame sits 1 inch further back on right side as oppsosed to left side
Wtf should i do im really ИИИИed off and dont know what to do???!!!!
Old 19-03-2006, 07:02 PM   #18
5L
[ 5L ]
5L's Avatar
i know when i got the guy to put my second hand steering rack in he said i had moved the k-frame back about and inch he indid it belted it forward with a mallet and did it up this moved it forward bout half an inch.
Old 19-03-2006, 07:11 PM   #19
XRated
Shoot.
XRated's Avatar
Damn that sucks. I went over a median strip about the same speed. Only ripped off two tyres from the rims. I took it to Pedders and there was nothing wrong
20V Turbo
XRated is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2006, 08:54 PM   #20
FPVWEPN
FPVWEPN's Avatar
if the k frame has been pushed back an inch on the left side would there be anydamage to the chassis?
Old 19-03-2006, 09:03 PM   #21
Polyal
The 'Stihl' Man
Polyal's Avatar
mate thats one for the professionals....
seriously, its not worth dicking around. Either fix it right or strip it. Its a hard call. i was qouted around $1500-2000 to fix mine when I did it, the one karl is refferring too.
Old 19-03-2006, 09:23 PM   #22
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
I did a similar thing a while ago in my EF. The bare minimum that needs to be replaced will be the lower control arm, radius rod and stub axle. Have a look under the bonnet, with impacts at such a high speed, its not hard to push the inner guard apart from the rest of the car, which will throw alignment out as well. There's also a fairly big chance the K-frame is bent.
It's possible, you might have just bent the K-frame, if you bent the chassis, you would be able to see it when you open the bonnet, the inner guards will have been torn away from the body where they're glued/spot welded on.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2006, 10:36 PM   #23
NZ
NZ's Avatar
where are you looking at the k frame from? If its from the front you might be comparing it to the lower support which is closer to the k frame on one side.
Old 19-03-2006, 10:55 PM   #24
EL_futura
mate...
They only do that so that they aren't held liable in case you have an accident after leaving there. Unfortunatley we now live in a time where everyone and anyone will sue someone for there own stuff up if given the chance.
Its just a matter of covering there own backs.
I actually work there (hopefully don't cop too much ИИИИ) and can say that we do actually know our stuff!
Good luck nonetheless...
Old 20-03-2006, 12:13 AM   #25
NZ
NZ's Avatar
Do you agree pedders charge like wounded bulls?
Old 20-03-2006, 01:53 AM   #26
FPVWEPN
FPVWEPN's Avatar
ummm the large nut holding the frame in has been bent backwards but i dont know if it has moved id really like to get some1 to look at it but i cant really drive it as its almost impossible to steer and very dangerous
Old 20-03-2006, 09:15 AM   #27
NZ
NZ's Avatar
Jeez that doesnt sound good! Maybe if you take some pics people on here could give you an idea of how bad the damage is. Exactly how hard did you hit the curb???
Old 20-03-2006, 01:34 PM   #28
Sundeep
Sundeep's Avatar
Dude I agree, that sounds like one for the pros. Might have to get the whole front end aligned at a panel beater.
If you need steering rack I will sell you one cheap cheap.
Sundeep
Sundeep is offline   Reply With Quote Multi-Quote with this Post
