Old 08-04-2006, 08:50 AM   #1
EL_futura
Default 5spd ea into el
as the tile sugests, does the 5 speed from an EA fit into an EL? An oppurtunity has arsien where i can get the whole car for dirt cheap, so i would be able to steal pretty much everything from this car, except the computer.
So would it bolt straight up? I know one of you guys has recently done a conversion, so i'd love to hear from you!
Matt
EL_futura is offline   Reply With Quote Multi-Quote with this Post
Old 08-04-2006, 09:43 AM   #2
naughtyfalcon
yep..same motor basicly,,just bolt it all up and a way ya go..
2000 AU Wagon
naughtyfalcon is offline   Reply With Quote Multi-Quote with this Post
Old 08-04-2006, 10:00 AM   #3
WINDSR
Genuine V8
WINDSR's Avatar
HSVETA did this conversion EA-EL a few months back.
Before FPV there was Tickford. Dont forget
WINDSR plates for sale. (VIC) PM if interested.
WINDSR is offline   Reply With Quote Multi-Quote with this Post
Old 08-04-2006, 10:14 AM   #4
niko
likes falcon's
niko's Avatar
ecu is kinda useless but, and you have to make modifications to your existing wiring loom, pedal box has a differnt brake switch, just make connectors for it and use that
www.carhubsales.com.au
niko is offline   Reply With Quote Multi-Quote with this Post
Old 08-04-2006, 10:39 AM   #5
Kenaz
Kenaz's Avatar
I *think* Walkinshaw put a EA T5 in his EL Fairmont.
02 BA XR6 T U R B O
Venom Red, Auto 13.97 @ 101mph
Originally Posted by Wheels Nov 02
It's suave, more subtle, and yet no less stirring. In fact, the boosted Ford is more polished than any big sedan Australia has ever produced. It's just so damn good, it makes the SS feel crude... Ignore the WRX. Forget the E49. Falcon XR6 Turbo is king.
Kenaz is offline   Reply With Quote Multi-Quote with this Post
Old 08-04-2006, 10:45 AM   #6
F6 Turbo
Posts: n/a
It will go in no problem, but the Flywheel and clutch are different EA / EB-EL.
Old 08-04-2006, 11:37 AM   #7
Damo
The clutch is smaller in an EA and has a 3 bolt presure plate as apposed to EB2 onwards which have a 6 bolt clutch, you can still use the EA clutch and flywheels though. Also the EA pedal box needs to be modified slightly, there are heaps of posts on this so do a search.
Damo is offline   Reply With Quote Multi-Quote with this Post
Old 08-04-2006, 12:20 PM   #8
banarcus
hmm eyebrows
banarcus's Avatar
Remember too that you will have no synchro for reverse. Before you put in reverse, just slide the stick into 5th and then back into reverse otherwise you will look like a noob when you grind the gears all the time.
XE 4.9 Falcon S & XA 4.9 Fairmont hardtop
banarcus is offline   Reply With Quote Multi-Quote with this Post
Old 08-04-2006, 05:42 PM   #9
svy08
svy08's Avatar
i put a ea box in my ed and had to buy a new rear yolk for the diff cos the ea ones are different
:eclipsee_ Cant save! my car is my Wallet
[]D [] []\/[] []D []\[]
svy08 is offline   Reply With Quote Multi-Quote with this Post
