Old 06-01-2022, 03:15 PM   #1
041
Default el falcon runs on gas.willnot ru on petrol,fuel pump runs @ full tank have changed computer.still wont go
el runs on gas wont run on fuel. fuel pump runs & full tank
041 is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2022, 03:20 PM   #2
Dr Terry
Default Re: el falcon runs on gas.willnot ru on petrol,fuel pump runs @ full tank have changed computer.still won
Have a look at the LPG/petrol changeover relay or its associated wiring.
Dr Terry
Dr Terry is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2022, 03:58 PM   #3
wodahs
wodahs's Avatar
are the injectors getting a pulse ?
can pick up a pulse lame real cheap and unplug an injector and plug in the diode lamp to see if injectors are getting pulse
think i paid under $20 for mine
and turned out to be the problem , then had to work out where and why they wernt getting the pulse from the ecu , think it was a bad connection some where but cant remember as was quit a few years back
yes still (as money n time permit) doing the
rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually
just remember don't be afraid to try something new.
Remember, amateurs built the Ark...Professionals built the Titanic!
I have taken up meditation... at least it's better than sitting around doing nothing !!
wodahs is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2022, 05:03 PM   #4
wodahs
wodahs's Avatar
could also be a fuel blockage and/or bypass valve stuck open so rail isnt getting pressure to the injectors
Old 07-01-2022, 06:59 PM   #5
INJECTED_250
Custom user title
INJECTED_250's Avatar
Just check you have 12v at the injectors when running on petrol. Used to cut the power on gas. . Most likely wire has been knocked of the relay check the loom, most likely spliced near the idle speed control solenoid ( as this needs 12v on both fuel and gas)
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
