01-04-2006, 07:25 PM | #1 | ||
Turbo TQE Operator
Its been a long time coming (parts bought about a year ago now) but its finally starting to come together
Sorry about the pic quality, but it was late in the afternoon in a workshop, with the sun shining at exactly the wrong angle, and taken with a phone. Obviously not finished, but getting there |
01-04-2006, 07:59 PM | #2 | ||
Smash the Boost
looking nice
surely these eseries turbos are melting the brake boosters...thats not heaps of clearance considering the heat
2023 Hyundai Palisade 1971 Fairmont Sedan 1974 SWB F100 Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
01-04-2006, 08:03 PM | #3 | ||
Turbo TQE Operator
Your very right there, a mate has a similar setup to me and melted to brake booster!! I'm having a heatshield made up for either the booster or the wastegate (the turbo is actually quite a long way from the booster) the dump pipe will be quite close as well, so probably better to put the shield over the booster, but we'll see what fits.
01-04-2006, 08:05 PM | #4 | ||
Come fly with P.S.I...
Looks tuff should make some good power, good luck with the rest of your project....
FG Turbo ute..lowered,20's Turbosmart Bov,Plazmaman piping,Flash tune coming...
01-04-2006, 08:35 PM | #5 | ||
Its coming along nicely mate... What kinda power figure you expecting?
01-04-2006, 08:45 PM | #6 | ||
Turbo TQE Operator
For the moment I hope it makes very little :
There is a 3psi spring in the wastegate but most people are getting 6psi with a 3psi spring and kyles manifolds on a GT35/40R. So hopefully it will only make 170-190rwkws. The auto is a little sad and thats the first stop after everything is fitted. Once the auto is sorted I'll wind it up a little, 10-14psi and shoot for 240-280rwkws. I'm sure the motor will die at this point (270,000k motor) and then I'll rebuild with low comp and wind it up to 18-24psi depending where I get the most power. Hopefully it will make around 360-370rwkws. It will be a LOOOOOONG development process, unless people want to make donations hahah : Will get it engineered at some point as getting it approved here in WA isn't quite as hard as most states. |
01-04-2006, 08:47 PM | #7 | ||
What colour were the springs in your wastegate?
Looking good.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. |
01-04-2006, 08:48 PM | #8 | ||
Turbo TQE Operator
Only a single spring, and its brown
01-04-2006, 08:55 PM | #9 | ||
Brown? Are you sure? Where did you get it from?
http://www.tialsport.com/documents/w3_tial_44_sp.pdf I just took mine apart, I got it from kyle also and it had 2 red springs in it. The red one is a 4.3 psi spring, the bigger red one is 10.1psi. edit: Im assuming you have a tial gate which you might not. The engine bay looks exactly like my old AU one, I miss it.
01-04-2006, 08:57 PM | #10 | ||
Turbo TQE Operator
I ordered it from XSpeed here in perth, my WG is a 48mm progate
Yeah I'm sure it was brown, it was ordered directly from the turbosmart catalog at XSpeed edit: Sorry to bring back the memories :( I'm itching to drive the damn thing |
01-04-2006, 09:01 PM | #11 | ||
Ahh now it makes sense. The engine should be alright for a little while, when I turboed my EB it had 300,000kms I ran 10 psi into it for about 15000kms.
Good luck with it all, turbo falcons are great fun!
02-04-2006, 02:02 AM | #12 | ||
FORMER T3 OWNER
dammm thats looking soo clean, cant wait to see the potential unleashed..
*droolz dammit i need to add mine to the boost list.
Mischief.TV you can sleep in your car, but you cant drift your house... |
02-04-2006, 10:50 AM | #13 | ||||
FPV GT Owner!!!
Produced about a 5cm crack in it. Why they make things plastic(water pump pulley) in these cars is beyond me. Quote:
@delta, what fuel and engine management you going to run??? Gotta love that pipework. Looks great.
Cars: - Ford Ranger Wildtrak - XY GT Replica - XB Coupe Project |
02-04-2006, 10:52 AM | #14 | ||
FPV GT Owner!!!
dbl post. sorry
02-04-2006, 10:58 AM | #15 | |||
7 would be perfect as a full time boost level. :
02-04-2006, 12:22 PM | #16 | |||
Turbo TQE Operator
Fueling is Bosch 044, 72lb/h injectors and standard regulator |
20-04-2006, 02:15 PM | #17 | ||
Turbo TQE Operator
Just a little update, the car went on the dyno for tuning yesterday and Problems Problems Problems, the car is overboosting (probably the wastegate outlet of the manifold is at the wrong angle) and the brake booster melted (expected this)
I should have got them to print me a dyno graph, at 3500rpm it put down 315rwhp and the graph was almost vertical |
20-04-2006, 02:22 PM | #18 | ||
PM me if you want
how much are you expecting it to make at full RPM based on that run.
20-04-2006, 02:29 PM | #19 | ||
What boost controller are you using?
It seems odd that the wastegate postion would cause your problems.
20-04-2006, 06:22 PM | #20 | ||
Turbo TQE Operator
there is no boost controller, and we checked that the wastegate is getting a proper signal from the intake manifold, so the only thing left is that the wastegate outlet on the manifold is at 90deg to the turbo outlet, and really only comes from two maybe three cylinders. The exhaust from the other 4-3 has to pass over the 6->1 collector to get out. The guys at ovaboost are going to do a cut n shut on the mainfold and move the gate to go off the turbine housing.
Heres a couple of pics of the manifold, its one from 6boost made by Kyle, absolute work of art, unfortunately it just can't get the exhaust out of the wastegate. |
20-04-2006, 06:26 PM | #21 | ||
Mmm merge collectors
My wastegate pipe is on the side closest to the camera in the pic right in the middle and closer to the flange. Have you spoken Kyle about it? He may have a better suggestion as to what the problem is.
20-04-2006, 06:27 PM | #22 | |||
Turbo TQE Operator
The car is meant to be running only 6psi or so atm till I get the gearbox sorted, so seeing that figure was both wonderful (will make good power later) and scary (bye bye gearbox). |
20-04-2006, 07:04 PM | #23 | ||
Turbo TQE Operator
Ok, just got off the phone with Kyle (hes certainly very helpful), he said putting the wastegate off the turbine housing should fix all . He was surprised that it had overboosted tho.
I'll let everybody know how it goes. |
20-04-2006, 09:31 PM | #24 | ||
ive got my gate of the turbine housing. it works well
# 1997 EL Falcon GLI - Custom built AU 4L bottom end, Billet Turbos B76-GTS, Nizpro plenum, 6boost manifold, Autronic SM4, Custom billet surecam camshaft, 3x 044 pumps and custom undercar surge tank, Custom 4" exhaust, ID2000 Injectors, 60mm Turbosmart gate, Turbosmart race port bov, , Tremec TKO 600, Cebco 330mm Brakes, 3.7:1 9" diff with billet axles and trutrack center 608rwkw, 9.6sec 1/4mile # 2008 FPV FG GTE - Xa Coilovers, 20x8.5/ 20x10 fairladys |
20-04-2006, 10:08 PM | #25 | ||
Turbo TQE Operator
Yeah I remember - I'm steve's mate btw, the one who was there with him at the drags. Hows your car going??? been down again?? I'm hoping to get the car together before they completely close off kwinana for the season, but its not looking likely :(
21-04-2006, 08:52 PM | #26 | ||
oh yeh i remember u. the car is in the shed at the moment getting the autronic sm4 hooked up and a few other mods. i havent been to the drags since i seen u. yeh i am also hopping to have my car ready before kwinana finnishes. i think the last wensday is in late may! might just get there i recon.
