Old 04-11-2021, 03:51 PM   #1
Tonz
Default full time reverse mirror
Past 4 years Ive had a Parkmate reverse mirror installed in ute, It is wired on full time as I use it for mirror due to covered in box on ute.
Its getting tired of working now the upgraded model
JB hifi $444
ebay $399
advantage of JB would be warranty IF it had problems...
your thoughts please
Old 04-11-2021, 04:27 PM   #2
Dr Smith
Default Re: full time reverse mirror
JB hifi $444
ebay $399
Not sure if this is the same model however you'll find Supercheap and Autobarn cheaper if near you.
https://autobarn.com.au/ab/Autobarn-...gaAvdQEALw_wcB
https://www.supercheapauto.com.au/p/...PO7454773.html
Dr Smith is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2021, 04:54 PM   #3
ozrunner
I've got this one in my ute as I have a separate dash camera and it's a neat fit as it replaces the standard mirror.
It switches to rear camera view when reverse is selected otherwise it's a normal rear view mirror but it's also wired via a dash rocker switch so reverse view can be completely turned off if needed.
I've got 3 camera's on my trays rear bumper, central, right and left side and it can be switched between either or have a central or split view, eg either camera on its own or left and right as a split view etc.
Had for approx 6 years and its always been set for on when reversing and I've had no issues whatsoever.
http://members.iinet.net.au/~ozrunne...cs/Mirror3.JPG
https://www.parkmate.com.au/products...mirror-monitor
ozrunner is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2021, 04:58 PM   #4
Tonz
Thanks Dr,
different model, slightly larger screen and needs original mirror to clip onto.
Ozrunner that is what I am after,
Can someone advise if the BA/BF mirror mounting is the same as FG
Old 04-11-2021, 05:04 PM   #5
Tassie f100
JB hifi $444
ebay $399
Whats getting tired,the camera or the moitor.If it is the camera,they seem to be interchangable between makes
Tassie f100 is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2021, 05:06 PM   #6
Tonz
nah the monitor has gone blank.
bugga now you got me worried....which is it?
I just presumed it would be monitor/mirror.
Old 04-11-2021, 06:59 PM   #7
Tonz
so went out to have a squizzz and when engine is turned on a 'no signal' appears on the screen, wiring back to camera looks OK.
So how does one test this to find out which item has got on the blink?
Old 04-11-2021, 07:27 PM   #8
Tassie f100
I would reckon the camera is the problem,probably the sealant has gone hard and let moisture in
Old 12-11-2022, 03:05 PM   #9
Tonz
update on old post.
Somehow I got all working but cannot remember how.
I now have a box trailer that has a 12v camera fitted, when we went to wire this into the full time reverse camera on the ute, we discovered the ute camera is 3.7v so we have a problem.
I have a camera, that works on reverse only that shows the towball and area around, the inside mirror was replaced with a camera mirror that is on full time showing behind ute,
So I would like to upgrade with new FLUSH mount 12v camera for ute and another mirror for inside. The latest ones can have a front facing camera as well but they mostly appear as clip overs not the windscreen mount.
So recommendations/thoughts/ideas please
