Old 21-11-2024, 01:18 PM   #1
ToyotaCorolla
Default few questions about 2008 ford focus LT
1. The engine is a Duratec-HE 2.0L. It says on the owner manual put RON 95, and on the service manual it say RON 91. Doesn't have a sticker on the fuel cover. Which one is it?
2. How to get rid of these bubble wrap on the back of the car? Tried looking for some plastic film cannot find it. Not looking hard enough?
3. Any solutions to the weak reverse light? You cannot see anything reversing in the dark!
4. What's this high pitch sound from 3 seconds seconds. What's shutting down?
https://www.youtube.com/shorts/obC62u5CEvY
5. If I accidental stall the engine, it just won't start for the next 2 minutes, its cranks but engine won't start. After 2 minutes it will start again. What's going on?
ToyotaCorolla is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2024, 10:21 PM   #2
XR5_2.5
2007 Ford Focus XR5 Turbo
Default Re: few questions about 2008 ford focus LT
1. 91 Octane is fine for your car, but it will probably perform a little better on 95 Octane, so it's honestly up to you...
2. The bubbles on your rear window is the aftermarket tint peeling away... Th only way to get rid of the bubbles is to take all of the tint off the window...
3. Do you mean the globe is dim? You can replace the globe for another halogen one, or even go for an LED light which will be brighter...
4. That high pitched whirring sound is the fuel pump, and it's normal for these cars to do this (my Focus XR5T does the same)
5. I'm not sure on this issue but I assume it's a manual... Is there any warning lights on the dash when this happens?
XR5_2.5 is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2024, 10:22 PM   #3
XR5_2.5
Is this your car or are you looking to buy it? If you're looking to buy it, then I probably wouldn't...
Old Today, 06:59 AM   #4
ToyotaCorolla
It's my own car!
There's nothing on the dashboard...
