Old 14-06-2006, 11:01 AM   #1
KP301078
Angry Urgent Expert Help Needed!!..
Hey guys,
I have a problem with my EBII Fairmont 6 cylinder.
Just recently it has been idling roughly when the engines warm, so on the weekend I changed the plugs and put new oil and oil filter in the old girl. Took it for a drive and dam it! it's still idling rough.
I then took out the air filter to see if it might be that and took it for a hard drive (revved it out to 4500rpms and revved fine) to see if it had a blown head gasket but still the same, only idling roughly!
I don't think its the brake booster as it doesn't loose fluid, but have a small leak in the power steering box.
Could it be:
The power steering leak
Spark plug leads
Moisture in the distributor cap
Clogged injectors
What do you think?????....
KP301078 is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2006, 01:33 PM   #2
eed-250
eed-250's Avatar
how does it idle?
does it sound like its on 5cylinders? or does it Hunt for revs?
4.0Lturbo
T56
AP Racing
520rwhp
eed-250 is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2006, 01:56 PM   #3
jeffb
jeffb's Avatar
Check vacuum lines and Idle speed controller
jeffb is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2006, 02:15 PM   #4
KP301078
Sounds like a 5 cylinder..... dips down from normal idle revs semi fast.
Thanks for your help!
Old 14-06-2006, 02:16 PM   #5
KP301078
It also drives fine when going along....only rough on idle???....puzzles me!
Old 14-06-2006, 02:17 PM   #6
KP301078
Also, the leads look pretty old on her.....
Old 14-06-2006, 02:25 PM   #7
XRated
Shoot.
XRated's Avatar
I'd change the leads and check the ISC first.
20V Turbo
XRated is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2006, 11:21 AM   #8
KP301078
Thanks that, will take a look on the weekend...
