Old 21-08-2006, 04:34 PM   #1
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
Default AU engine into EF..
Hi guys
Just wondering if anyone has done this?
I know about the Sump cutting required, but wondering what other mods need to be done for the Serpentine, etc? Do all of the EF accessories bolt upto the AU engine ok?
Regards
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2006, 04:40 PM   #2
SWOOP
XRSVO
SWOOP's Avatar
apart from sump everything else should be pretty straight forward
pretty much all accessories are interchangable ,the aircon may need work and check ignition setup on both is same design ,trigger ,sensors etc
just use a AU block and head with your ef gear
SWOOP is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2006, 04:41 PM   #3
EFFalcon
Last warning
EFFalcon's Avatar
bell housing doesn't bolt up 100%, but a few ppl just leave it anyway.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 21-08-2006, 04:58 PM   #4
Christiaan
Christiaan's Avatar
kewl,
do you know the best way to modify the sump to fit? I know you have to cut and weld, but is there any tutorial on exact measurements?
When you say check ignition, do you mean coil pack, etc?
It's an EF XR6, so should i put the XR6 head into the AU block, or leave the AU head on there?
Old 21-08-2006, 05:11 PM   #5
SWOOP
XRSVO
SWOOP's Avatar
Originally Posted by shuresm58
kewl,
no sorry got no Idea , youll have to get a custom one made up, EF crossmembers suck .....
yes check that fittings are same
personally id leave the au head on it with a hp cam and vernier ,sell the "T" head and get a unichip or something to tune it
Old 21-08-2006, 05:21 PM   #6
SiKoRa_eL_97
SiKoRa_eL_97's Avatar
Insurance ? :P
SiKoRa_eL_97 is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2006, 05:34 PM   #7
Christiaan
Christiaan's Avatar
Insurance for what? Why would insurance matter?
Old 21-08-2006, 06:54 PM   #8
BOOSTDEF
FPV GT Owner!!!
BOOSTDEF's Avatar
You will need an AU alternator. And an AU drive Belt.
I modded my k-frame and its still going strong 5 months later.
I found you will also need to run premium as all i got was pinging when running NA with just the AU motor and an exhaust.
IMO, it is better to mod the k frame as the AU sump is designed to transfer strength in the bottom end.
Cars:
- Ford Ranger Wildtrak
- XY GT Replica
- XB Coupe Project
BOOSTDEF is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2006, 09:26 PM   #9
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
and if u hate petrol co$t$ just so u know AU heads [I]hate[I] gas
EF Wagon Project:
Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required
Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB
Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's
the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA
CaRtZ is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2006, 11:29 PM   #10
Smoked
Burnin Rubber
Smoked's Avatar
What??????
2001 AUII Forte (LPG)
K&N Air Filter
Tickford Air Intake
***Coming Soon: Clear Side Repeaters***
Originally Posted by The-ShowStoPPa
...dont get me wrong this 3.8v6 is pretty special, it does come with the popular shake rattle and roll option and the auto compliments this with the ever popular snap crackle and pop feature
Smoked is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2006, 11:47 PM   #11
Christiaan
Christiaan's Avatar
Originally Posted by Smoked
What??????
Yeah, didn't ya know?
AU Taxi's run methanol because LPG wrecks the head.. :
